GS Tune-up
Old Jun 13, 2006 | 12:47 PM
GISHKA's Avatar
GISHKA
Default GS Tune-up
I have an 01' GS 300 with almost 50K miles... I read all those Lexus brochures about check ups and tune ups, but I don't believe their $$$-sucking marketing. Anyways, I wanted to know what essential things I should do to my car to keep it in tip-top shape...
Should I change the timing belt?
What is the best transmission fluid to use on a GS?
Should I change the water pump and the fuel filter?
Thanks.
Old Jun 13, 2006 | 12:53 PM
Lexbox's Avatar
Lexbox
Thanks.
Timing belt and water pump are done at 90k. There is only ONE tranny fluid you should use and that is the Type IV fluid from Toyota. DO NOT use anything else!
Old Jun 13, 2006 | 12:57 PM
GUNRU-GS4's Avatar
GUNRU-GS4
No timing belt and water pump till 90k.
I think there is a 60k service recommended for the GS. Probably includes all fluids being changed, check your air filter, maybe check your ball joints. Your car probably does not need more than standard fluid changes depending on the maintenace history. You have pretty low mileage, not much to worry about.
corkycal's Avatar
corkycal
did you buy it used? if so, you may want to check if the prior owner did all the scheduled maintenance. if you don't know, i would change all the fluids just to be on the safe side.
all the big items:timing belt/water pump/spark plugs are done at 90K.
Old Jun 19, 2006 | 12:10 PM
ByThaBay's Avatar
ByThaBay
I disagree with this statement. Amsoil ATF has provided above expected performance / wear quality on my Trans.
Old Jun 22, 2006 | 02:19 PM
AUGuy21's Avatar
AUGuy21
Default Re:
I got my transmission fluid flushed at Express Oil Change 6 months ago. I wonder if I am in trouble?!?!
Old Jun 22, 2006 | 02:29 PM
Lexbox's Avatar
Lexbox
It is definitely something to look at.
Calcio
GX - 1st Gen (2003-2009)
12
May 24, 2013 04:14 PM
toytrain13
Sep 25, 2012 08:35 AM
EyeKutr
Nov 23, 2009 05:52 AM
ted920
Maintenance
13
Oct 29, 2005 08:37 AM
tobal
Dec 30, 2004 08:15 AM
