Transmission Problems?
Originally Posted by JacobT
I have my tranny replaced at dealer once at 40k miles under warranty. The after market TC triggered the CEL and dealer could not determined the causes, so they had to replace it under warranty
did you take out the aftermarket TC before you brought it to them or they just not notice it was aftermarket TC?
BTW-there was recently a member with a GS430 that had his trans replaced 2X under warranty. can't remeber name.
Originally Posted by smello12
C I had went to aamco to get a flush of the trans and he told me that he would not do it because the trans fluid was too dark and could cause it to slip he wouldn't even drain the fluid. He also said that the trans would fail in the fall, that was 2 years ago.
I think that's a misconception now. Fresh fluid is never a bad thing. If there is nothing wrong with your car, then replacing fluid isn't bad. Now if there is something wrong with the tranny, and you replace the fluid, then there could be problem(s), but the tranny is to be blamed for, not the fluid changing.
A guy on my old forum use to change his tranny fluid every 25k miles, and his car currently has about 340k miles, on original tranny.
Originally Posted by chuckb
that's one way to change your fluid
That's the painful part. I had to swap the stock TC back in to get that new tranny
Of course I got a new TC as well
Originally Posted by aliti19
Wow - i change mine every 15K. Think i'm overdoing it? My buddy (Lexus tech) tells me to do it, so i listen.
I never encountered any problems with it, except for lag acceleration but I'm sure all you GS guys can relate. Ever since I would drain and fill the ATF every oil change. Two quarts out, two quarts in. I'm at 90k miles right now, not a problem yet. :crosses fingers:
Anyone got a picture of where to drain tranny fluid,and also a picture of where to refill tranny fluid. I'm not with my car at the moment, but i am performing the rest of my 90k mile service and this is one of the few things left on my list when i get it back. Thanks,
John
John
Originally Posted by DynamicCK
Mine used to shift irregularly after driving it hard.
did you replace the tranny because of the CEL or was it acting up?
John
John
