Help APEXi S-AFC
Old Sep 17, 2001 | 10:54 PM
  #31
CSHFLW's Avatar
CSHFLW
So do you hook the injector and the RPM to the purple harness wire together?
Cuz it has "purple wire (RPM Signal * Injector Signal)"
And about this manifold input the HW-10 or what ever....did you do this? Could some setting be the problem with the throttle position?
Also what mods are you running? and Can you share your AFC setttings?
Old Sep 18, 2001 | 10:06 AM
  #32
GS4K's Avatar
GS4K
Pann,
the correct throttle position wire is 3 pins directly left(Red/Black wire) of the Air Flow Sensor in Diagram T10a. I just got it to work today. I'll let you know the results of my dyno tune tomorrow.
Old Sep 19, 2001 | 09:34 PM
  #33
Pann's Avatar
Pann
GS4k
Congratulation, I 'll try to fix it tomorrow. Thanks for the info and let me know how' s dyno. p.s. I think you right about the other guy.
Pann
Old Sep 20, 2001 | 05:50 AM
  #34
GS4K's Avatar
GS4K
I went to a different dyno and I baseline at 237 rwhp and 259 ft/lbs torque. After setting my A/F Ratio to 13. My peak increase was 10 hp and 12 ft/lbs torque. But in some areas I did increase over 20 hp. I'm really happy with the increase because the increase of hp and torque was throughout the diagram.
Old Sep 20, 2001 | 09:54 AM
  #35
RacingAristo
Guest
Posts: n/a
What kind of intake do you guys use?
Old Sep 20, 2001 | 10:35 AM
  #36
The Ikon's Avatar
The Ikon
Not bad at all for $300 bucks!!! Given your peak was 20hp and the average of 10hp and 12lb tq. I wonder what the increase would be with different settings? One member on the SC forum "MadMaxSC400" with his SC4 got around 18 - 20hp average and 28 peak if I'm not mistaking. I saw "ComputerWiz" s-afc in his SC3 this past week end at Nopi. "93sc3005spd" has a s-afc too... Maybe you all can get together on some settings to optimize the unit's ability to perform on the car.
What numbers did "BananaGS" get with his S-AFC? I thought they were higher than the ones you got at the dyno.
The Ikon
Old Sep 20, 2001 | 11:16 AM
  #37
CSHFLW's Avatar
CSHFLW
You guys are running the GS400....settings would be completely different with the 300....any one here dyno there GS300 with the S-AFC?
Old Sep 20, 2001 | 04:11 PM
  #38
GS4K's Avatar
GS4K
I did see the post with the sc getting around 30 rwhp. I was happy to get 10 maybe I could have gotten more if I had a air intake and exhaust? I'm going to wait until next year for this.
p.s. - you can't just take someone elses setting and plug them in. Not all cars are the same. You should always get your car dyno tune with the s-afc.
Old Sep 20, 2001 | 04:30 PM
  #39
LexusRules's Avatar
LexusRules
could someone please find the T10a Diagram, use a paint program and label it with exactly what has to go where and what color each wire is? someone that has done it and it worked for them. this woudl be greatly appreciated by all!!! for the GS300 or 400. thanks
Old Sep 22, 2001 | 11:14 AM
  #40
GS - T.O.'s Avatar
GS - T.O.
Here is a T10a diagram that come from Apexi's manual. Can someone point out what really need to go where? Thanks!
Old Sep 22, 2001 | 12:51 PM
  #41
LexusRules's Avatar
LexusRules
exactly what i want to know
Old Nov 10, 2003 | 10:44 PM
  #42
Mariusz's Avatar
Mariusz
I was searching the forums and found this thread on the SAFC. I had the SAFC2 in my car to see if I can get some fine tuning in before going standalone and I wired everything according to this diagram.
https://www.clublexus.com/forums/sho...m&pagenumber=2
I also saw what Apexi recommends for the GS400 (T10a). I know mine was working fine and I am curious as to how you guys got yours to work tapping into different places for RPM and TPS. I wish I had the Lexus ECU diagram to see but I don't.
Old Nov 11, 2003 | 03:04 AM
  #43
GILLEXUS's Avatar
GILLEXUS
Do you know if this diagram for the S-AFC will work for the GS430? Or does it have a different hot wire set up?
Old Nov 11, 2003 | 08:54 PM
  #44
Guru's Avatar
Guru
Here's the diagarm for the S-AFC II for the GS400. I know it's correct since I made it.
Old Nov 11, 2003 | 09:39 PM
  #45
Dee's Avatar
Dee
Default i have the s-afc
i have had in it my car for about six months now and i did see a dramatic increase in hp when i leaned the car out i have a gs 400. i wrote the instructions down after i figured out wich wires to use but i have to look for them. i will put them up as soon as i find them
