Swaping out Diff GS300 to a GS400
Old Mar 31, 2006 | 04:53 PM
criminalR1's Avatar
criminalR1
Lightbulb Swaping out Diff GS300 to a GS400
Hey Guys I was just curious I should be able to swap the GS300 Diff 3.92 in place of my 400 diff 3.26 ......I have one laying around and even though its not an LSD I figured it would make the car a lil bit more fun with the gearing I just not sure if there is a differance between the 2 or if is a direct bolt in .
Thanks...............
Old Mar 31, 2006 | 05:04 PM
rwheelz's Avatar
rwheelz
I have searched and read a number of threads on this, and it should bolt right on. The traction will be worse than stock without a LSD, but the car will certainly be more responsive and accelerate quicker.
Not sure if this will cause you problems with hitting the rev limiter, but I would ask around before installing it!
Old Mar 31, 2006 | 06:27 PM
JeffTsai's Avatar
JeffTsai
Someone told me that the SupraTT rearend will not bolt onto the GS300. It will only work with the GS400/430. So I think this might mean that theGS300 and GS4/430 have different tranny configurations....if thats the case then the GS3 rear probably wont work on your car. Whoever knows more on this subject please correct me if I'm wrong.
If I'm wrong then I'll be happy since that will mean I can use the 3.76LSD rear when I drop boost on the summer
Old Mar 31, 2006 | 07:07 PM
benzo555's Avatar
benzo555
Jeff
The Supra TT will bolt on a GS300. Even L-tuned parts sell the entire pumpkin and so does RMM as a rebadge Supra TT pumpkin.
Old Mar 31, 2006 | 07:19 PM
JeffTsai's Avatar
JeffTsai
Originally Posted by benzo555
Jeff
Hm, thats good news, but I searched on my old posts and it was rominl that said it wouldn't work.
Originally Posted by rominl
the drive shaft part that connects to the pumpkin is different, you need to change that one way or the other
Someone please explain?
Old Mar 31, 2006 | 07:28 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Jeff not sure of the context., but I think it may be about the torque converter which is a different part on the 300 when you replace it with aftermarket.
Old Mar 31, 2006 | 11:08 PM
JeffTsai's Avatar
JeffTsai
I'm talking about the rear end...the whole "pumpkin" unit.
porn-adkt
17
Nov 2, 2012 09:10 AM
denut-L
Performance
14
Jul 8, 2009 11:01 PM
adamgamz
Sep 11, 2008 07:50 AM
AW99GS400
Performance
Mar 25, 2008 06:24 PM
JeffTsai
Nov 13, 2007 06:27 PM
