SupraTT Brake Upgrade: Question for those who have it...
Hi Guys,
I might have come across some used Supra TT calipars and rotors(not used) and was wondering if the stock GS brake lines connect directly to them. I heard talk concerning this. Was wondering if I could do the Calipar and Rotor upgrade without swapping out the brake lines...
Brent
Brent
Brent,
They will fit fine, just make sure you use new washers. The crush washers that are on the car now may not give a complete seal when you put on the new/old calipers. The stock brake lines will not line up directly as on the stock caliper, but it will fit, just make sure when you position it, there isn't much tension. If you want, I can take a picture of mine and send it to you.
aloha ricky
aloha ricky
Guest
Posts: n/a
I've called Island Motorsports at Buena Park. They are not familiar with Lexus GS so they wouldn't install those SupraTT for me. Then they referred me to some place at Gardena where I got a quote for $2800! Does anyone know a shop where they can install this brake package for a reasonable price?
p.s. the shop will need to shave off the calipers a little cuz they won't fit in my rims.
Thank you very much.
Brent
Guest
Posts: n/a
The reason I'm only looking for a brake specialized shop is that the calipers need to be shaved in order to fit inside my 18" rims as JacobT mentioned before. I will pick up my SupraTT brake kit tomorrow (monday) from Steve and see what he can offer to help. So far I'm pleased by Todd's work. Basically he did all the suspension installation for me.
tinygs,
Thanks for your info. I will keep looking.
tinygs,
tinygs,
tinygs,
He did my 60K service for like 300 bucks or so...including all factory OEM Lexus parts...Compare that to any dealer...
Brent
Guest
Posts: n/a
JacobT,
Please check your PM.
JacobT,
The PM is currently down now so I answer your questions here.
If I remember right, you'll need to shave about 1/8" from the surface.
It costed me $130(2 hour labor) to install both front brakes. There're only 2 screws you need to remove to get the caliper off. It's really easy. Shaving will take you more time than installation.
Originally posted by JacobT
Dennis,
Dennis,
Brent
Guest
Posts: n/a
I just came back from Carson Toyota. After talking to Steve, I'm not so sure about the brake upgrade. He is a very honest guy and told me that if he were me, he wouldn't shave the calipers for the safety reason. I also asked Todd and he also has the same concern. What am I gonna do?
Guest
Posts: n/a
Dennis,
Are your RH C5 on 44mm offset? If that's the case the you have no choice but either shave the calipers or use spacers.
I just came back from Dallas meet, I ran my car with some high speed racing and stopping in a vacant mall parking lot. I had no problem at all. I've talked with some Supra guys and they told me shaving is common in SupraTT with after market wheels.
Guest
Posts: n/a
Jacob,
I'm thinking to take my car to Laguna Seca this Dec and don't want anything goes wrong, including my car parts. If shaving is truly unharm and very common, how come shops here at Los Angeles aren't willing to do so and even Steve told me not to do it? Please enlighten me. Thanks.
Dennis
Dennis
