First Cel Need Help
Old Nov 28, 2005 | 07:34 AM
sockfocks's Avatar
sockfocks
Default First Cel Need Help
OK...so i'm driving around the other day going about 40 and the CEL light comes on. I swing by jonny's later on to use his OBD scanner. The code is a P1055 i think. "O2 Sensor malfunction heater circuit bank 2 sensor 1" any clues on how to fix it? We reset the code and it came back on within 2 hours. I'm not familiar with the emissions on a GS. I'm thinking the sensor is probably ok, but I dont know what the heater circuit is?
Old Nov 28, 2005 | 02:37 PM
sockfocks's Avatar
sockfocks
C'mon...does anyone have the emissions section in the repair manual i can read?
Old Nov 28, 2005 | 05:03 PM
Dx3's Avatar
Dx3
Joe,
I should receive my manual anyday now so I will let you know.
Bump
Jonny
Old Nov 28, 2005 | 06:36 PM
Vette Boy's Avatar
Vette Boy
...code is a P1055 i think. "O2 Sensor malfunction heater circuit bank 2 sensor 1" any clues on how to fix it? ...I'm thinking the sensor is probably ok, but I dont know what the heater circuit is?
Bank 2 Sensor 1 is the rear sensor before the rear cat (3.0 L6, right?). If it's not a fuse, and unless you replaced the sensor, my guess is the sensor's heater died, time for a new O2 sensor. If both sensors are original, I'd replace both.
If you've replaced the sensors recently, I'd check the connector to be sure no smashed pins.
Old Nov 28, 2005 | 07:45 PM
sockfocks's Avatar
sockfocks
ah...fuse huh?...have to check it out...any idea on how much the O2 sensors are?
Old Nov 29, 2005 | 05:43 AM
Vette Boy's Avatar
Vette Boy
There are two items I only buy the dealer/OEM, sparkplugs and O2 sensors. I think the dealer wants ~$70 each, AutoZone/PEP Boys will be ~$35.
Old Dec 3, 2005 | 05:08 PM
sockfocks's Avatar
sockfocks
Well thanks to jonny (dx3) i found out sensor 1 is the one closest to the engine, bank 2 is the one NOT connected to Cylinder 1. I didnt see a fuse in the schematic. It basically told me three things. ECU, 02 Sensor, Wiring between ECU, Main Relay, Sensor. So i'm off to mess with the connector, do an ecu reset and see if that works. If not I'm gonna break out the ohmeter and check the sensor itself.
PandaGS300
Apr 6, 2015 01:40 PM
00&02rx300
RX - 1st Gen (1999-2003)
Jan 27, 2010 06:17 AM
nicos1
Nov 5, 2007 05:47 PM
p4ult
Jun 13, 2007 01:08 AM
jmoonan
Maintenance
Dec 7, 2005 07:36 PM
