Does anyone have problem with steering wheel?
Old Oct 12, 2005 | 02:11 PM
Gs L-tune's Avatar
Gs L-tune
Default Does anyone have problem with steering wheel?
My steerign wheel telescope won't drop down. Anyone have this problem? some people told me the fuse but i dont think thats the problem
Old Oct 12, 2005 | 06:54 PM
landarc's Avatar
landarc
HI. I sometimes get this problem also. It will telescope in and out, but won't tilt down. For me it seems to happen intermitently. I am thinking its weather related. I am not sure of the cause, but I am going to ask my dealer. I will let you know.
Old Oct 12, 2005 | 06:57 PM
GWELEX's Avatar
GWELEX
I would think it's in the switch itself not the fuse. Do you have memory seats? Does it go down using the memory function?
Old Oct 12, 2005 | 07:10 PM
landarc's Avatar
landarc
I have memory seats. If the tilt doesn't work, then when I select the memory seat, it still doesn't tilt to the position it was saved. It is weird and anonying.
Old Oct 12, 2005 | 08:14 PM
GWELEX's Avatar
GWELEX
Sorry man it's now beyond my abilities. I was thinking if the memory still worked the steering wheel we could probably identify the switch on the column as the culprit. Now with nothing moving the steering up and down it sounds like a wire or electric motor problem. I don't know if there are 2 separate motors to adjust the steering wheel, if so your first piece of advice about a fuse might be valid. Good Luck, hopefully someone more experienced here can help.
Old Oct 12, 2005 | 08:43 PM
Gs L-tune's Avatar
Gs L-tune
yea it happen to both my GS and SC
Old Oct 17, 2005 | 09:05 AM
Two-Times's Avatar
Two-Times
Default Me too...
It's happening to me too. I have a 98 GS400. It's so annoying. It works sometimes and at other times doesn't.
hlippy4
May 22, 2018 06:32 AM
SH212
May 1, 2008 06:14 PM
roxanne
Oct 1, 2007 08:45 AM
vietstuh
Mar 20, 2007 12:33 PM
99LS400
Maintenance
May 1, 2004 12:00 AM
