HELP!! on wrapping the bench arm rest.
Subscribe
Aug 5, 2005 | 11:58 AM
ok, i bought new leather from the GB. im stuck on how to do the cut out of the rear bench arm rest. does anyone have pics or can tell me the correct way to do this. thanks
Reply 0
Aug 5, 2005 | 12:31 PM
Quote: ok, i bought new leather from the GB. im stuck on how to do the cut out of the rear bench arm rest. does anyone have pics or can tell me the correct way to do this. thanks
okay
here goes , use a flat head screw driver large size and gently bend back the meatl sleeve around the cup holder , just enough to get the oem one out .. once you have pulled the material out the slip theleather off
slide the new one over and get a sharp razor blade and cut one slit directly in the middle where the actual slide out cup holder wouldpertrude out , then carefully start to push the material in around the inside of the metal sleeve.. be patient it will take about a hour to get it right .. work all the way around gently pushing it inside the sleeve..
good luck
Reply 0
Subscribe
