Beginner Mods questions..1st time user
1. I ordered a new SRT intake....will be installed at the end of the month
2. I just received my new TRD Strut Tower for the front (will also be installed at the end of the month).
Do I need / have to have one on the rear as well?
3. Since my 16 in. platinum style rims are slightly bent on all 4 tires, I am looking into 4 new ones sometime this summer. I plan on 18's as the largest size.
- Although I like the staggered look, does it make since to actually get it since I do a lot of traveling and would like to be able to rotate tires around to maximize life on the tread?
- Also, any pics of a (silver) GS with 18's to show good examples would be appreciated
4. Does it make since to replace factory rotors with drilled/slotted rotors for looks. Brembo? or other brakes. Not looking for big brakes though. Also, would like to paint the caliphers (probably black). Anyone else have extra white LEXUS stickers for them?
thanks for any info in advance.
Q2. I just received my new TRD Strut Tower for the front (will also be installed at the end of the month).
A2 - Nope, the STBs work independently. If you were talking about sway bars, you should do both front and rear.
Q3. Since my 16 in. platinum style rims are slightly bent on all 4 tires, I am looking into 4 new ones sometime this summer. I plan on 18's as the largest size.
A3 - Although I like the staggered look, does it make since to actually get it since I do a lot of traveling and would like to be able to rotate tires around to maximize life on the tread?
Nope, link here with more info https://www.clublexus.com/forums/sho...d.php?t=164493
Lots of them in the gallery.
Check this recent thread
https://www.clublexus.com/forums/sho...d.php?t=167444
Also look for pictures of TomTNC (also in Charlotte) and Hameed (among others) in the gallery
TomTNC
Not rotors, but you'll want to do pads at the same time https://www.clublexus.com/forums/sho...d.php?t=161779
Please make sure to try the search feature of our forum... we've got over five years of threads and just about everything you can think to ask has been covered many times.
Hope you can make it to some of our local meets sometime.
if you do alot of traveling i guess get the same width all around ..better off in the long run
Did I see them on Swift Racing Tech. website...the HRE's 545 or something like that?
we'll have no problem helping you spend that money
