GS 300 Trunk Slam Update!
Old Feb 9, 2005 | 12:17 PM
Machog's Avatar
Machog
Default GS 300 Trunk Slam Update!
OK, all you guys out there with GS 300's with slaming trunks because of an aftermarket spoiler. Here's the scoop.
If you have a genuine Lexus spoiler added to your GS trunk, it will weigh less than 5lbs and the 400 springs will work fine. Real Lexus spoilers are hollow.
If, like me you have an aftermarket non-Lexus spoiler, (typically solid and weigh in at 7 to 10lbs), new 400 springs won't help. Only thing you can do is to re-drill a hole about 20 30 degrees closer to the back of the car, as suggested by others. It won't lift up, but it will stop it blowing down on you and trying to de-capitate you! I put in rubber gromets and bit of greace so it wouldn't get a chance to rattle.
Tx to Darrell Diller at Lexus Parts in TX for the information, he could have sold me a couple of 400 springs, but gave me some excellent free advise instead-kudos Darrell. Machog
Old Feb 9, 2005 | 08:02 PM
rominl's Avatar
rominl
exclusive matchup
ah this is some nice info, thanks for the update! amazing how that couple more lb can do to the trunk
Old Feb 9, 2005 | 08:29 PM
gs4rocks's Avatar
gs4rocks
Actually, drilling another hole is not the best way to deal with this. I tried that but it only improves marginally. Carson Totoya has the stiffer tension bar for sale. I'm not sure if that's what you are referring to as springs. The black one in the picture is the stiffer replace bar. It only looks a little thicker, but it's whole log stronger than the original. I used the middel hole, and I have to press down on the trunk to close. I have the after market spoiler that's about 10 lbs.
Old Feb 9, 2005 | 08:32 PM
TLW's Avatar
TLW
https://www.clublexus.com/forums/sho...threadid=29600
MsLeng
Feb 18, 2016 01:59 PM
Loyalone72
Jul 10, 2015 01:44 AM
Loyalone72
Aug 31, 2013 10:54 PM
Machog
Feb 5, 2005 04:55 PM
gr8330
Jun 19, 2002 06:34 AM
