Vsc Light On And Abs Light On?
Old Feb 20, 2006 | 04:28 PM
maaloxx's Avatar
maaloxx
Has anyone tried this? The instructions fromth e PDF file above.
Old Feb 22, 2006 | 10:43 AM
maaloxx's Avatar
maaloxx
Anyone? Bumb
Old May 16, 2006 | 10:25 PM
erftimmeh's Avatar
erftimmeh
Default same problem
did anybody ever found the solution to this? i had the same problem when i turn my wheel one side my vsc light turns on, but now everytime i start the car its on. and oh yeah btw it was b/c i just did my suspension with my friend today.
Old May 17, 2006 | 12:43 AM
erftimmeh's Avatar
erftimmeh
to the top!!!
Old Oct 20, 2011 | 12:22 PM
airahcaz's Avatar
airahcaz
to the top!
Old Oct 20, 2011 | 12:50 PM
Hypebeast's Avatar
Hypebeast
It's the #15 fuse.
Old Oct 20, 2011 | 01:04 PM
airahcaz's Avatar
airahcaz
Originally Posted by Hypebeast
It's the #15 fuse.
searching for #15 is a little tough - where is it?
Old Oct 20, 2011 | 04:28 PM
DosyBoy's Avatar
DosyBoy
If your number 15 fuse is bad and IF its the same as my gs400 then it will be on the drivers side kick panel underneath by the e-brake pedal, if your fuse is not bad i would suggest disconnecting the battery for 30 minutes then letting the ecu reset.. Lemme know what happens, your fuses starting under the drivers kick panel start off with:
1-2-3-4-5
6-7-8-9-10
11-12-13-14-15
5th fuse last on the 3RD ROW
Old Oct 20, 2011 | 05:00 PM
porn-adkt's Avatar
porn-adkt
Next to the #14 fuse.
BTW..I hope to god you know where your fuses are.
Old Oct 20, 2011 | 06:32 PM
airahcaz's Avatar
airahcaz
Have never needed to change a fuse in my car - will try disconnecting my battery tomorrow first
Old Oct 21, 2011 | 01:54 PM
sakataj's Avatar
sakataj
do you have a owners manual? ALL the fuses and the fuse #'s are in their.....IF you dont, in the stickies on here you can get access to the manual
Old Oct 21, 2011 | 02:07 PM
airahcaz's Avatar
airahcaz
I found it thanks, looked at it, and it is fine, fuses are not my issue it seems
Old Oct 21, 2011 | 02:54 PM
sakataj's Avatar
sakataj
FOR THE UMPTEENTH TIME NOW MAN, YOU RIPPED THE SPEED SENSORS WHEN YOUR BALLJOINTS GAVE OUT, you can rebump EVERY thread in the world about this but the bottom line is until you either replace or repair that sensor these lights are not going away without removing the bulbs.
Old Oct 24, 2011 | 08:47 PM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
Brian, that's uncalled for man, there no point to call someone out like this, sir I'm sending you a pm now. I'm closing this thread
KDHarbour
Apr 26, 2021 10:44 AM
ISFinferno
IS F (2008-2014)
Jun 17, 2016 06:53 AM
CalMike
Nov 10, 2014 01:20 PM
tom8757
Dec 15, 2012 05:51 PM
illson_2k
May 30, 2003 01:17 AM
