Car stutters when pulling in second gear
Old Mar 27, 2025 | 03:19 AM
Sillypickle445's Avatar
Sillypickle445
2nd gear
Default Car stutters when pulling in second gear
So when I try to pull in second gear it tends to stutter at high revs and sometimes there's a whining noise coming from the transmission. But when switched to third gear it goes smoothly at higher revs and everything
Old Mar 27, 2025 | 11:37 AM
CPTSOLO's Avatar
CPTSOLO
How many miles on the car?
Looks like you may have blockages in the transmission's valve which prevents shifting.
Before that blockage destroys your transmission and cause a very expensive replacement, try to replace the fluid. If it does not improve, try a transmission flush. If it does not improve, the problem is not caused by the transmission.
Toyota / Lexus recommends transmission service every 50K miles or sooner. Dump the fluid and clean the filter and the pan of any debris. A flush is recommended every 100K.
Old Mar 28, 2025 | 04:11 AM
Sillypickle445
2nd gear
The car has 400000 km on it. The engine itself is fine and hasn't lost power after all this time, surprisingly. I did a transmission flush a couple of months ago and it seemed to improve the situation, but now i tried doing a pull and its stuttering again. Thank for the reply
Troels
Apr 3, 2023 02:48 PM
user 710812323
Feb 16, 2020 11:41 PM
05RollaXRS
LFA Model (2012)
12
Nov 2, 2013 10:21 PM
bad co
Jun 14, 2009 02:18 PM
Falcon LS
Nov 10, 2004 08:35 PM
