Just curious if anyone else has experienced the issue I'm facing with my GS300 2003. I got the VSC/ABS/VSC OFF lights last week and got two codes: C0200 Front speed sensor RH circuit and C1223 ABS control system malfunction. I cleared the codes and started getting this buzzing noise (video link attached) while moving sub 20MPH along with a weird brake pedal sensation sometimes. While pressing down on the brake pedal , when the car is almost stopped, the pedal lets up on the resistance significantly until the car comes to a full stop. I replaced the front right ABS/Speed sensor today and the issue remains.
To Summarize:
VSC/ABS/VSC OFF
Buzzing noise sometimes while traveling sub 20MPH
While breaking near the bottom the pedal lets up on the resistance significantly
Here is a link to a video with the noise:
Any help would be greatly appeciated!
To Summarize:
VSC/ABS/VSC OFF
Replace the wheel speed sensor first. If issues still persist then it's quite possible the ABS master cynlinder unit going bad.
https://charm.li/Lexus/2003/GS%20300...8%20DTC%20%29/
https://www.clublexus.com/forums/ls-...223-c1201.html
https://www.clublexus.com/forums/gs-...and-c1223.html
https://www.clublexus.com/forums/gs-...ode-c1223.html
