Transmission issues, possibly a solenoid?
Old Jan 13, 2025 | 08:20 PM
JaySco's Avatar
JaySco
Default Transmission issues, possibly a solenoid?
2001 GS300. No codes, no CEL, seems to shift fine in manual mode but really revs out between 2-3 I believe. When driving conservatively in D it seems ok but when you get on it it’s very noticeable. My son (his car) said the other day going up a hill it was not wanting to downshift. Trans was making a rattle sound the other day, one quart low. Added fluid and sound went away. Fluid already in there looked fine (still red, not burnt). Does this sound like a solenoid to you or something more serious?
Old Jan 14, 2025 | 06:03 AM
TrueGS300's Avatar
TrueGS300
A solenoid issue is sure to throw a code. You may want to have it scanned by a shop with a scanner that can read the transmission specifically. Not all codes set the CEL. If no codes are present, it is not likely a solenoid issue. When you say "really revs out" do you mean slippage/high rpms? Or it just wont shift and continues to try and pull before without upshifting? You may need to look as the throttle/APP as these have a lot to do with shifting.
Old Jan 14, 2025 | 09:57 AM
JaySco's Avatar
JaySco
Yes, slippage /high rpm’s. Darn, I was really hoping for a simple solenoid but it sounds like that won’t be the case. Already making plans to have it diagnosed. Thanks.
Old Jan 16, 2025 | 05:22 AM
TrueGS300's Avatar
TrueGS300
Unfortunately slipping isn't a solenoid issue, it's worn clutches that can't hold anymore. Time for a rebuild or replacement.
Old Jan 16, 2025 | 04:52 PM
JaySco's Avatar
JaySco
So it turns out the erratic behavior of the trans was a side effect of an exhaust that was super restricted thanks to a cat that had self destructed. Still not a cheap fix but a lot easier!
mzeitlin
May 29, 2024 06:58 AM
Klao
RX - 1st Gen (1999-2003)
Oct 29, 2023 08:15 AM
aeggerth
GX - 1st Gen (2003-2009)
Oct 24, 2023 07:59 AM
Mando44
Jun 29, 2023 07:09 AM
teaa
Apr 10, 2023 08:26 AM
