2001 ga430 w/nav w/ml radio harness foe aftermarket radio
7th Gear
Hi guys. Im hoping i fan find a wiring diahram for a 01 gs430 that has nav and the ml system. I fant find anything online. Im doing a full aftermarket audio system so do not need to retain sny factory speaker wires or sub. I just need to situate the yellow and red 12v wires the ground and blue amp turn on wires and possibly illumination. I'm pretty sure they do not make a metra harness for this at all so I'll have to tap into some wires.
There are a few harnesses to get for power and lights, but nothing to get the speakers. Just need to cut the plug at the amp.
The wire colors at the speakers match the colors at the amp plug. So now you don’t need a diagram. Hey, but if you decide you do, let me know and I’ll take some photos of the diagram.
IIRC I used Scosche TA02B (similar to the 2nd pic shown above) for the + - and illumination and Metra 70-8116 for the stock amp bypass (so you don’t have to run new wires all the way to the speakers).
7th Gear
I all ready ran new 14 gauge wire. Im runnint a 3 way front stage and 6.5s forna rear fill. Ill have two 4 channel amps if I was going to habe to end up extending wires any ways might as well upgrade. I have both of those harness posted above but none of them match with the pin outs. My guess is those work with the ones with the amp in the glove box and now the ml with the amp in the trunk. The harness look totally different.
