P0125
Car: 2001 GS 300
Issue: P0125 Insufficient Coolant Temperature
What I replaced so far:
Radiator (Megan Radiator)
Radiator Fans (Aftermarket)
Thermostat (Dealer)
Radiator sensor (Dealer)
Coolant sensor in on the block of engine (Dealer)
I don’t know why it shows this code, I replaced almost everything that is coolant related but it still shows up. Any suggestions?
Thermostat (Dealer)
Get a way to read your ECU's accessible outputs such as coolant temp with something like the Torque app and a compatible bluetooth OBD2 plug. Then you'll be better informed about what's going on and this should help you troubleshoot things better.
This can be caused by a bad O2 sensor or wires. This happened to me. The harness had a broken O2 sense wire.
Use a DMM to check O2 voltage on the upstream sensors. Best location is at the ECM.
akafixture
Oct 4, 2018 08:29 AM
Brutus213
Feb 20, 2017 12:35 AM
