Uneven worn tires causing drift?
My front tires started having uneven wear along the edges because I aligned it about 6 months ago and somewhere in between that time the front toe slipped slightly out of spec and for those couple thousand miles I drove, they are unevenly worn. I moved them to the rear since I needed to do a rotation anyway. I notice over some uneven roads if I’m going over 60 I feel the rear drift out a little. Prior to this I felt it doing this in the front wheels. After alignment the front feels solid but that drifting is really bothering me. Do you think the tires will eventually even out since I moved them to the rear? These tires have about 5000 miles on them only.
