Starting problem
Old Jun 27, 2021 | 11:47 AM
lucithelex's Avatar
lucithelex
Default Starting problem
I have a 96 Lexus and yesterday I put my battery in wrong after replacing my pwr steering pump and ac bypass pulley started just fine before now all I get is a click noise lights turn on but my cluster and steering wheel aren’t operating, I’m thinking I messed up my stator because I checked all fuses and they are all good any tips would help a lot thank you
Old Jun 27, 2021 | 11:31 PM
Arsenii's Avatar
Arsenii
Hello,
What do you mean by "put the battery in wrong", did you reverse polarity?
Clicking noise generally indicates a dead battery rather than something else, check the battery voltage with no load and while cranking the engine, it should not go below 10-11V; besides, any car parts store should be able to check your battery for free. If it is a bad battery, then there is a question of whether it's just old or there is a parasitic draw, I described how to check the latter in this post.
Hope this helps and best of luck!
Old Jun 29, 2021 | 06:53 AM
joewitafro's Avatar
joewitafro
probably fried one of the larger fuses.
AEMxRACER
Sep 8, 2009 01:35 PM
tonka2711
Mar 22, 2009 07:17 PM
dsabc2867
Nov 17, 2008 09:13 PM
Batmobile
May 11, 2006 04:22 PM
lex400sc
Jun 2, 2002 07:27 PM
