HELP w/ TEIN's
Old Sep 23, 2003 | 08:31 AM
jdmdaddy's Avatar
jdmdaddy
Exclamation HELP w/ TEIN's
As some of you know, I installed my HA's on Saturday. However, the right rear coilover is only able to adjust just a little bit like 6 clicks (stiffness **** @ top). where the other ones are fine and i can adjust them ok.
what could be wrong? should i tear it down today and inspect it for anything jammed up inside?
Thanks in Advance,
Craig
95 GS
Old Sep 23, 2003 | 01:10 PM
kts_GS3's Avatar
kts_GS3
Sorry, can't help you there. You might want to check in the Suspension Forum. They may have an answer for you there.
Good luck.
Old Sep 24, 2003 | 04:57 AM
Mischievious GS's Avatar
Mischievious GS
was it able to adjust all the way down before you installed them?
a little off topic...after i installed the tein's, it seems like something is loose in my rear right strut. when i go over bumps slowly, it sounds like the spring is loose or something is rattling. any of you had that problem? i've tightened the bolts all the way, but it still rattles.
Old Sep 24, 2003 | 06:28 AM
jdmdaddy's Avatar
jdmdaddy
yes i have that problem too! it sounds like its rattling from the upper mount. only on my right rear its doing this. And Yes, I was able to adjust them. Now we are talking about this piece right?
I can adjust the perch just fine. Just not the top **** for the stiffness....
thanks,
Craig
Marclacson
Suspension and Brakes
Jun 26, 2018 11:17 AM
77i9
Apr 4, 2012 05:41 PM
1SICKGS400
Dec 9, 2011 09:17 AM
chris_D
Aug 13, 2011 09:12 AM
