Changing starter
Old May 6, 2016 | 07:22 PM
hassan86's Avatar
hassan86
Default Changing starter
Hello everyone
I am usually really good at working on my own vehicles. Hondas, Chevy's, fords and a mkIII. But this gs300 starter is kicking my ***. Could someone please give me some pointers? I can't get to the bolts under the car or on top. Can't find any video's on it. Read a form that said to take the trans down and, one that didn't mention the trans but, wasn't very descriptive.
Please help
Old May 8, 2016 | 06:21 PM
TheMole's Avatar
TheMole
From what I remember, I did mine from under the car when I had my 1gs. I used a combination of long and wobble extensions.
Old May 24, 2016 | 10:07 PM
kene's Avatar
kene
I removed the 2 starter bolts from underneath the car using wobble and long socket extensions. Im sure you are aware, but for those who may read in the future disconnect the battery before removing anything on the starter. You can thank me later.
Once the starter's electrical plug was disconnected and the 2 bolts were removed, i stood up, opened the hood and removed the starter out from the hood engine bay. Not from underneath the car. Trust me, it can be done.
You will just have to move/angle the starter in different positions until you get it jut right. It will barely squeeze through.
Remember exactly what angle younpulled the starter out at because you will beed to squeeze ir back in the same way.
I hope this helps. Oh and rockauto had a 3 peice starter rebuild kit for 12$(8 years ago). It was a cinch to do. I myself used it and have been rockin the original(rebuilt by me) starter since then.
Originally Posted by hassan86
Hello everyone
Please help
Old May 24, 2016 | 10:13 PM
hassan86's Avatar
hassan86
Thank you for your reply. I have got it changed after a few hours of struggle and frustration.
I come to find out there are 3 blown capacitors. Just found out today, whole reason I have issues. After replacing all the sensors.
I'm just not sure where to get them? They are nichicon 100uf 10v 105c. Afraid of getting the wrong sizes. If you have any idea what and where I should be looking id appreciate it.
Old May 25, 2016 | 12:05 AM
kene's Avatar
kene
Click in the link below, and after the page loads, click on the button called "show products". All capacitors shown are 100uF, +105C, but the voltage ratings are electronically beefier (higher voltages than 10volts)
http://www.mouser.com/Mobile/Passive...word=Capacitor
For online electronic components I lean more towards www.mouser.com and www.digikey.com comes second.
Old May 25, 2016 | 12:13 AM
hassan86's Avatar
hassan86
Awesomeness! Thank you very much.
Project300
Sep 8, 2021 06:53 PM
raphytaffy
17
Jan 8, 2015 04:21 PM
OneJay
Aug 15, 2011 03:24 PM
sockfocks
Maintenance
Jun 17, 2006 07:06 AM
dundfaukus
Nov 5, 2004 04:28 PM
