need some advice asap
Old Oct 23, 2012 | 10:23 PM
onelt1's Avatar
onelt1
Buy the Toyota head gasket kit and everything else aftermarket. eBay has some good stuff but they have some bad stuff too. I bought the head gasket kit from eBay and used almost everything except the head gasket because I didn't need it at that time. It also doesn't come with all the intake gaskets, it's missing the upper Y gasket.
Old Oct 23, 2012 | 11:38 PM
MikeC7909's Avatar
MikeC7909
I'd personally pick up new head bolts as well. I believe the current ones are probably shot after all them miles and the overheats. More money..but a good precaution.
Old Oct 24, 2012 | 12:50 PM
onelt1's Avatar
onelt1
I forgot that one, I would change them even if they had a 100 miles on them, because they are torque to yield Bolts.
Old Oct 24, 2012 | 03:24 PM
2GSC300's Avatar
2GSC300
I would buy the coolant, sealant, water pump, head gasket and frontseals from Toyota. Supra non-turbo parts are the same. I would get everything else aftermarket. I would change the plugs, plug wires and valve cover gasket while you are there.
Old Oct 25, 2012 | 05:01 PM
badboylx04's Avatar
badboylx04
thanks 2gsc300 i almost forgot about the wires n spark plugs,i did some research on the water pump for toyota n aftermarket n i found one aftermarket that is o.e not o.e.m but is to act like oem i know lots of people agree to get oem but i havelots of people telling me other wise like the headgasket even thou the oem is suppose to be better but its a metal headgasket just like the aftermarket n works the same unless u get a 2ply head gasket or copper one .i kno oem timing belt forsure i got to get n i decided to get the fluids n filter for the trans from toyota
JraztikGS
Feb 11, 2014 08:08 AM
Casper9604
Jan 7, 2013 02:52 PM
luckyis300
IS - 1st Gen (2001-2005)
Jun 11, 2011 09:19 PM
soarer18
Aug 13, 2010 06:53 PM
Idryfly5
Mar 27, 2010 03:56 PM
