TPS sensor
Old May 9, 2012 | 06:32 AM
lexlugerrr's Avatar
lexlugerrr
Default TPS sensor
I thinkbthe tps sensor on my gs gave out. Car won't even go into gear unless its completly cold or I have to detach the battery cable and connect it then it will run fine for a while. I was wondering if you guys had any idea what the problem could be. It seems that its a sensor because it shift just fine when its cold or I detached the battery and reconnect it. Has all the symptoms of a bad tps sensor. So unwashed wondering if anyone had a DYI STEP BY STEP instructions on replacing it and where its located
Old May 23, 2012 | 09:18 PM
Jmai22's Avatar
Jmai22
Incase you need one
https://www.clublexus.com/forums/gen...2-22090-a.html
Kingdom
RX - 1st Gen (1999-2003)
Mar 25, 2009 05:13 PM
ChocosLS430
Sep 6, 2007 06:40 AM
