93's Rear windows wont function.
Old Jan 16, 2011 | 01:01 PM
SadKamper's Avatar
SadKamper
Default 93's Rear windows wont function.
Hey CL. Came for some need of help, to understand why my both rear Windows are not functioning. Is it because burnout fuses? I bought the car like that, So I do not know the causes for not to work, if it use to make mechanical problem or etc.
Appreciate any responds thank you.
Old Jan 16, 2011 | 01:24 PM
deknick's Avatar
deknick
if you push the button to open it, does it make ANY sound?
it may be as easy/common as a snapped cable on the regulator, or a burnt out motor, as i don't think it would be a fuse, since all 4 should be on the same fuse
Old Jan 16, 2011 | 04:54 PM
jrbury3's Avatar
jrbury3
check the wires between the door and the car. when I bought my car (93), the wires were so tight that they just broke from the opening and closing of the doors. Both rear doors so I would have thought it was common.
Old Jan 18, 2011 | 10:53 PM
SadKamper's Avatar
SadKamper
@deknick True, It makes no sounds.
@jrbury3 I will check that out.
Old Jan 19, 2011 | 11:05 AM
deknick's Avatar
deknick
if it makes NO SOUND at all, the motor is shot, or disconnected, or has a break in teh wires, most likely exactly what jrbury3 mentioned.
lt1fire
May 13, 2021 06:45 PM
gtimax
Mar 1, 2014 03:08 PM
krye
Aug 30, 2010 04:32 AM
sexysc
May 10, 2006 10:41 PM
