ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS - 1st Gen (1993-1997) (https://www.clublexus.com/forums/gs-1st-gen-1993-1997-120/)
-   -   93's Rear windows wont function. (https://www.clublexus.com/forums/gs-1st-gen-1993-1997/547201-93s-rear-windows-wont-function.html)
SadKamper Jan 16, 2011 01:01 PM
Hey CL. Came for some need of help, to understand why my both rear Windows are not functioning. Is it because burnout fuses? I bought the car like that, So I do not know the causes for not to work, if it use to make mechanical problem or etc.
Appreciate any responds thank you.
deknick Jan 16, 2011 01:24 PM
if you push the button to open it, does it make ANY sound?
it may be as easy/common as a snapped cable on the regulator, or a burnt out motor, as i don't think it would be a fuse, since all 4 should be on the same fuse
jrbury3 Jan 16, 2011 04:54 PM
check the wires between the door and the car. when I bought my car (93), the wires were so tight that they just broke from the opening and closing of the doors. Both rear doors so I would have thought it was common.
SadKamper Jan 18, 2011 10:53 PM
@deknick True, It makes no sounds.
@jrbury3 I will check that out.
deknick Jan 19, 2011 11:05 AM
if it makes NO SOUND at all, the motor is shot, or disconnected, or has a break in teh wires, most likely exactly what jrbury3 mentioned.
