2000 GS300 drive light,temp issues
Old Aug 9, 2010 | 02:15 PM
bossco416's Avatar
bossco416
Default 2000 GS300 drive light,temp issues
I'm having a huge amount of issues with my car as of late.
Last week I took my car in to do the brakes.
The following day noticed a huge leak on my driveway.
Took the car back and nothing was discovered with respects to the leak. ( I myself no nothing about cars )
They took me under the car and pointed out what could be a possible future fuel leak. But my fluids were looked at and all seemed well.
So now one week later I'm in the car and driving home.
My AC turns off and the center console that displays the outside temperature reads -- (as opposed to the outside temperature). This lasts about 30 seconds of so, the outside temperature reappears and the AC comes back on.
In addition to the temperature/AC issue, the fuel cluster (unsure of correct name) has multiple issues. The light indicating my car is in drive goes on and off. When off the temperature gauge also drops down. And after driving for about 10 minutes a constant flashing begins of my low fuel icon. However I have more than enuff gas.
I'm waiting to take it in for service, and I am livid.
The car did not have any of these issues prior to going to this shop. I shop I have never used before but was directed to by my father in law.
Old Feb 13, 2011 | 03:19 PM
AlsRisto98's Avatar
AlsRisto98
you might want to check the charge for your alternator...When it is about to go on you, you will have the dash lights start to flicker and gauges go crazy...One way to check if your car is charging right would be to turn the car on, remove the positive cable off your battery while on..If the car does any gesture of shutting off or jerking...Might be there..Is the cheapest way to start troubleshooting that issue
Old Feb 19, 2011 | 10:54 AM
skylitejdm's Avatar
skylitejdm
start your car and take the positive charge plug off if it still running then your alternator is good.. this can be some harness problems. so what electronic upgrade have you installed on your car?
mshmsh
Mar 10, 2020 06:42 PM
Mimi17
Oct 28, 2017 12:08 PM
mohannad12
Build Threads
Apr 16, 2014 01:12 AM
jason36
Aug 1, 2012 06:37 PM
isiginamo
Apr 21, 2008 05:12 PM
