Alternator Question ( FAST REPLY )
Old Dec 10, 2009 | 12:08 AM
r0k0's Avatar
r0k0
Default Alternator Question ( FAST REPLY )
i need to know what happends if i put a higher Amped Alternator than the Stock 80Amps one.. will it fry something on the engine for having more Amps output than Stock or it you benefit on having a little more amps for like radio, heating fan and heated seats..?
max i would be would be 100-110 amps..
Thanks
Reason i need fast reply.. my Alternator just fryed and i need a new one ASAP
Old Dec 10, 2009 | 05:25 AM
plkyone's Avatar
plkyone
Should be fine just as long AS the voltage regulator keeps the voltage under 14v. i think one of the supra alternators is a 100 amp not sure of the exact model.
Old Dec 10, 2009 | 05:38 AM
r0k0's Avatar
r0k0
they do not saying anything about the voltage... only amps..
they say they all fit GS300 with 2JZ GE 93-2000 so i guess they should have the right volts.?
Old Dec 10, 2009 | 03:15 PM
r0k0's Avatar
r0k0
found on local for 230$ canadian... oh well.. i needed one asap and its a 80amps like stock
Old Dec 10, 2009 | 04:24 PM
plkyone's Avatar
plkyone
yea it will work that amp should be no problem
Old Dec 20, 2009 | 10:12 PM
bill4agze's Avatar
bill4agze
If your circuitry is used to weak amps because of your alternator, then just by getting a new alternator might have adverse effect on your power seats / radio ect. That happened to my GS. You might have to address electrical problems one at a time after you replace the alternator. This is known to happen if you have been running a weak alternator for a long time, then suddenly change to a new alternator.
jshooter55
May 23, 2010 05:55 PM
seanjonstu
Nov 20, 2006 03:09 PM
ted920
Aug 2, 2006 08:43 AM
retrodrive
Oct 29, 2002 09:42 PM
