Correct ABS-light functioning
Old Jan 14, 2009 | 11:40 AM
ReneV's Avatar
ReneV
Default Correct ABS-light functioning
Is the ABS light on the dashboard supposed to be on when the ABS is active?
Last edited by ReneV; Jan 16, 2009 at 06:28 AM. Reason: simplified, in the hope that someone might answer ...
Old Jan 16, 2009 | 11:15 AM
Mikes94GS3's Avatar
Mikes94GS3
No, just the opposite, it's inactive when the light is on.
Old Jan 16, 2009 | 02:31 PM
AaronStaub's Avatar
AaronStaub
no. nice optimism tho.
Old Jan 16, 2009 | 04:21 PM
ReneV's Avatar
ReneV
By `active', I meant easing off on the brake-fluid pressure to prevent wheel lock, i.e., ABSing, if you wish. I did not mean `is the unit monitoring what is going on?' Sorry.
Anyway, the answer appers to be `no, the light only ever comes on at ignition or if there's a fault; there's no indication of ABSing when it happens other than the physical feedback from the pedal, etc.'
(Right?)
It seems odd that the TRC light should come on when it is actively doing its thing, but that the ABS light should not. I know they are different colours, but really, honestly ...
[EDIT: actually, they are both yellow, go figure ...]
Old Jan 16, 2009 | 06:38 PM
AaronStaub's Avatar
AaronStaub
Given what is going on when the ABS is doing its thing, the car shouldn't really need to tell you its trying to help. Is your light on constantly?
Old Jan 16, 2009 | 07:10 PM
ReneV's Avatar
ReneV
No. It's only on at ignition. I just had the ABS/TRC unit replaced with a used one, and I have a vague recollection of seeing the ABS light when I thought the ABS was helping out in the past, but that's probably wrong. I probably confuse it with the TRC light, which is flashing when the TRC is TRCing.
Bottom line: my brakes and traction are working correctly now, and I have no missing indicators.
tom8757
Dec 15, 2012 05:51 PM
TriniLex
Oct 24, 2011 08:47 PM
dlb993
RX - 1st Gen (1999-2003)
Feb 1, 2010 06:20 PM
onslaught
Oct 5, 2009 03:17 AM
illson_2k
May 30, 2003 01:17 AM
