Code 31, code 24 [merged threads]
Old Aug 25, 2008 | 10:13 PM
amart79196's Avatar
amart79196
Default Code 31, code 24 [merged threads]
Hey,
I have a 1995 GS300 and pulled a code 31. According to my research the code means that "low airflow meter voltage"
Is it safe to say that there is something wrong with my Mass Air Flow sensor??
Thanks for your time in advance.
Old Aug 25, 2008 | 10:16 PM
amart79196's Avatar
amart79196
Default Code 24
hey again,
I have a 1995 gs300 and pulled a code 24. After some searching on this forum, I have not gotten a difinitive answer as to what it is that could cause this code to occur. From what I have gathered, the "Intake temperature sensor circuit fault" is what the code means. I also learned that code 24 means that the IAT is at fault.
Is the IAT the same as the MAF?? If not, could someone describe it or post a pic of it?
Thanks so much in advance for your time and effort.
Old Aug 26, 2008 | 01:42 PM
Kaiser's Avatar
Kaiser
The intake temp sensor is integrated into the Karmen Vortex sensor(maf). If you swap the unit you take care of both. It's located right before the filter box and the harness has 6 wires coming out of it.
Old Aug 26, 2008 | 03:36 PM
amart79196's Avatar
amart79196
swapped out and fixed! thanks a million
Calin72
Hybrid Technology
Mar 29, 2019 11:50 AM
Talapo
May 15, 2017 11:58 AM
imDementeD
Mar 8, 2011 01:03 PM
SC300_704
Jan 29, 2008 09:33 AM
