Squelling noise...
Old Jan 22, 2008 | 06:36 PM
LeXusFiTs's Avatar
LeXusFiTs
Default Squelling noise...
When I start my car in the morning there is a kind of squealing noise. After the car warms up the noise goes away. I had this problem with my Acura TL before and it turned out to be my water pump. I checked the water pump and it seemed fine (no leaks). Has anyone else had this problem before?
Old Jan 22, 2008 | 09:09 PM
Duds's Avatar
Duds
Check your belts for cracking if not just lubricate your accessory pulleys.
Old Jan 22, 2008 | 10:30 PM
AirForceGS's Avatar
AirForceGS
Trying spinning your fan by hand to see if it turns smoothly also. If not replace your fan clutch ASAP. I started hearing noises under my hood and my fan clutch actually seized up (I didnt know at the time) so my fan was constantly spinning at engine rpms. On my way to my family's house in Cali coming from Vegas I guess I was going fast enough to where the fan created a strong enough vacuum to suck the lower piece of the fan shroud into the fan. 200 miles from my destination with a shattered engine fan. $270 from Lexus the rest is history. I had to get it from Lexus because I couldnt find it anywhere else and I needed to get back to Las Vegas.
Old Jan 23, 2008 | 12:03 AM
VIPdaily's Avatar
VIPdaily
could be your pws pump going bad....i started hearing it when it was cold, but when it got warmer it went away...now its constant, i checked the resevoir and its still got fluid.
Old Jan 23, 2008 | 02:57 PM
Kruso's Avatar
Kruso
Calm down everyone, its just a belt. Happens all the time in winter time. Replace the $20 belt and you'll be fine.
Kruso
Old Jan 23, 2008 | 06:25 PM
LeXusFiTs's Avatar
LeXusFiTs
Kruso
LOL Thx guys for your input.
Old Jan 26, 2008 | 07:40 PM
atl4love's Avatar
atl4love
i hoope it is the belt...some time the crank pulley go bad..they start to making that kind of noise and i end up paid for the new one or else you gonna get stop without goin nowhere...check for the crack between the plastic and the metal of the crank pulley...good luck
Jackiew
GX - 2nd Gen (2010-2023)
32
Jul 10, 2017 04:32 PM
sam12345
Jul 31, 2016 01:57 PM
Wronglane
GX - 1st Gen (2003-2009)
13
Dec 22, 2014 05:26 AM
jdog0411
Mar 13, 2012 10:04 PM
Salil022
Dec 27, 2008 12:05 PM
