MPG improvement available?
Subscribe
Jul 5, 2007 | 05:19 PM
After a few trials of filling up my tank and recording the miles i get, my average per tank is about 18-20 mpg. I know some might say that this is pretty good for our gs, but is there anything that i can do to help raise it up a notch? Customise air intake? CAt-back exhaust? Some say that these two don't really help much in mpg, but performance. Any advice will be greatly appreciated.
Reply 0
Jul 5, 2007 | 07:59 PM
Put more air in your tires.
Reply 0
Jul 5, 2007 | 10:19 PM
Intake, new spark plugs, gas WITHOUT alcohol (like the higher blends)... Remember you need 30% more alky then you do gas to run stoich... I found that NOT running 94 gives about a 50-80KM boost on my old volvo. So when I'm doing road trips I usually just fill 91 since I know I'll not be using the high octane as to try to conserve during the long drive which means no real boosting.
More air as Kaiser said, change trans / lsd fluids, check breaks to see if they are dragging.
Put on smaller wheels that arn't so heavy, remove any items form the trunk that you don't need.
Reply 0
Jul 5, 2007 | 11:24 PM
Valvoline fuel system cleaner.
Reply 0
Jul 7, 2007 | 02:53 PM
Quote: Put more air in your tires.
I normally run about 35-38psi. Is that not enough or do I have to put more? How much psi do you guys run?
I have my stock 16's on so they're not too bad. I do still have my winter tires on though. Don't know if it's good in the summer or not, but it seems to be running fine and fuel consumption isn't much of a difference.
I'll try the Valvoline fuel system cleaner. Isn't Lucas or Seafoam better? Or perhaps Chevron?
Reply 0
Jul 8, 2007 | 01:26 PM
ok i'm avraging about 400-450 ish a tank now but i have been getting on it during that tank.. I can't stay out of boost it's just too damn fun.
Reply 0
Subscribe
