what do you guys think?
Old Mar 24, 2007 | 03:54 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
Man i can say for you its ur money..... but i thought u had all these parts allready . again its ur call GO FAST OR LOOK GOOD??
Old Mar 24, 2007 | 04:35 PM
faceoff101's Avatar
faceoff101
i dont have the parts in hand but i have the cash in hand so thats no problem i wish i can have both my girl says relax youll get it were you want it
Old Mar 24, 2007 | 11:15 PM
gs300pnp's Avatar
gs300pnp
Registered User
My suggestion... I've been in your shoes and like Tony says its your call..
Below are some things to ask yourself..
do you want the show or the go?
If its show, then get the body restored. otherwise then do the na-t conversion.
Whats your goal as far as rwhp?
next one is the killer...
Do you intend to keep your car for a while?
Whats your realistic budget?
Are you street racing, strip or just want more go?
If you're going to open up the engine or pull it out, consider refreshing the internals. but when you do this, things will start to add up and before you know it you'll be spending $8k for motor refresh. this is a full-blown machining, blueprinting and balacing. i.e agressive knife edgeing the crank,
you'll need to check rings for wear, main and thrust bearing for wear etc..
take your time and make sure you review your options and not to overlook other expenses you will incurr during as well as after your project. you may reach a point where you've sunk in thousands of dollars doing things the right way and then suddenly run of of capital or have a change of heart. but this time its tool late to go back, otherwise you will loose time.
Old Mar 25, 2007 | 09:54 AM
faceoff101's Avatar
faceoff101
i guess ill get the minor things done before the upgrade no sense in having a go ride when theres nothing to show
nino1877
May 8, 2015 11:40 PM
poorsupra
Aug 4, 2012 08:48 PM
Na-TuralSC
Feb 10, 2009 09:20 AM
dohc3ltt
Dec 8, 2007 06:48 AM
rw3
SC400 / 300 Classifieds
May 31, 2007 10:40 AM
