2jz-gte swap
Old Jan 28, 2007 | 07:19 PM
SCSJ's Avatar
SCSJ
Originally Posted by Kaiser
I've seen motorsets for $1800. I paid $2500 shipped to my door for a whole half cut.
yeah that about the same price that i can get at the local shop here
Old Feb 2, 2007 | 05:15 AM
SprtDesign's Avatar
SprtDesign
Supra USDM Motorset complete would work? ECU, mounitng points ect?
Old Feb 2, 2007 | 08:47 AM
Kaiser's Avatar
Kaiser
The motor will fit, the ECU and harness will not easily. I'm sure it's possible with enough time and money and pin outs. But why would you when the Aristo harness plugs in.
Old Mar 15, 2008 | 11:35 AM
2slow4u's Avatar
2slow4u
With doing the 2jz swap in to a Gs300 i understand the motor drops right in and you need to make clearance for the twins; however if you go single its a little easier. Now with the wiring has anyone developed a write up for the extension of them? Can you utlize the Aristo ECU for this swap? and final question is there a write up for the 6spd/5spd conversion for this car?
Old Mar 16, 2008 | 09:07 AM
Raph TT's Avatar
Raph TT
just use everything from the aristo..including the wiring harness.. then extend the wires just before the ecu plug..
Old Mar 16, 2008 | 11:32 AM
handoverfi's Avatar
handoverfi
great thread on the supraforums for the NA supra and SC's
http://www.supraforums.com/forum/sho...d.php?t=255935
Here is even a more detailed one but the guy is dropping it in a supra.
http://forum.clubna-t.com/showthread.php?t=5151
so if anyone needs more info look at them sites and threads alot of good info!!
Old Mar 19, 2008 | 06:53 PM
DWB_Shop's Avatar
DWB_Shop
ok sorry to ask questions... im doing a aristo 2j swap... into a 98 gs300 VVT-i motor... the aristo harness will plug right in when extended correct... i know NOOOOB
Old Mar 19, 2008 | 11:03 PM
status....'s Avatar
status....
if the vvti motor is going into a 1gs i'm pretty shure the wires are different, unless it came out of a 1g aristo in japan already
Old Mar 20, 2008 | 09:29 AM
Lexatlast's Avatar
Lexatlast
CL Folding 100,000
depends on what engine you are swapping in. What kind of 2jz-gte is it? VVTI or not? if you're tryin to put a non-VVTi into your 98 gs3, it will not be plug and play at all.
if it isa VVTi 2JZ-GTE, VVTi's are notorious for being complicated and you'll probably need to modify something but i'm not sure on this. i doubt it will be plug and play.
Old Mar 29, 2008 | 09:37 AM
gs300pnp's Avatar
gs300pnp
Registered User
I don't advise the VVTi on the JZS147. Reason, 1st gen's use analog signaling whereas the later 2nd gen and present all use digital signals.
Also, the internal chassis wiring harness of the 1st gen that the engine harness plugs into is different.
Nazar
Lexus Vehicles Classifieds
14
Jun 30, 2012 11:47 AM
1sikcrx
Performance
Aug 10, 2008 07:01 PM
GlobeCLK
Performance
14
Feb 21, 2007 05:33 AM
jdmjunk
Dec 1, 2005 10:11 AM
