Dyno'd again today
Old Dec 9, 2006 | 06:24 PM
Kaiser's Avatar
Kaiser
Default Dyno'd again today
Had an enlightening experience today. The AFC does not read boost properly once you exceed 1.0 BAR. My AFC said I was cruising around town on 17.5psi if converted from bar. I layed down 350rwhp and was quite upset. Then thought about it and the odds of running that boost on 91 octane were slim. We hooked up another boost gauge to discover it was under 15psi. Once we turned up the boost to a solid 16psi and let the heat soak cool, I layed down 380 rwhp. Using that much boost I had to zero out my fuel correction as I was initally pulling fuel. With the BCC in place the map sensor is limited to 4.28v and I have no power to add any fuel. As a consequence I am running lean and mean at about 12:1 air fuel at 16psi. 380rwhp seems to be enough for me. My 10" wheels start skipping off the pavement as the rpms climb. I'll post the chart as soon as I get it converted from runviewer to jpg. I'm sure it's near or at 400 on a cool night.
Old Dec 9, 2006 | 10:16 PM
Abear's Avatar
Abear
CL Folding 200,000
Awesome man. 350whp on 15psi is pretty impressive, so is 380 in 16!
Old Dec 11, 2006 | 07:54 AM
Kaiser's Avatar
Kaiser
Old Dec 13, 2006 | 08:03 AM
Epik's Avatar
Epik
hopefully I'll have some new #s to add up here soon. I'm fine with it as long as I have 381 rwhp.
Still no BCC here though and I doubt I'll pick up that extra 26rwhp on the USDM cam. I'll be cool with it as long as I make around 370 though.
Still looking for a solution for the JDM map sensor though.. heading over to SF to check out that post and add my $.02
yell0w
May 26, 2013 08:46 AM
stockhatch
Oct 20, 2010 06:21 AM
blaznsc4
Jun 3, 2007 08:18 PM
Dx3
Performance
25
Feb 20, 2006 06:12 PM
LedZepig
Oct 29, 2004 02:17 PM
