Bulb question
Old Apr 12, 2006 | 10:10 PM
jmax.garage's Avatar
jmax.garage
Default Bulb question
I have JDM lights and the day time runing light is a 194 bulb. I've seen pictures like this one
and also several other with this mod. I wonder how they do it....
Old Apr 12, 2006 | 10:31 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
JDM lights have an extra socket for a light known as the "city light". It is usually an led.
Old Apr 12, 2006 | 11:28 PM
indypwr's Avatar
indypwr
all you gotta do is tap the wires on the turn signal bulbs.......when you turn "on" your parking lights, the city lights will be "on" as well.
Old Apr 13, 2006 | 06:48 AM
jmax.garage
well that I know. i also have an LED on the day time runing light and the wiring is done correctly, to the point that my turn signals DO NOT turn on as day time running lights; my headlights are working pretty much like JDM ones. My question is what kind of bulb is that, or how do they do this mod and how do they wire it?
Here is another pic:
https://www.clublexus.com/forums/att...id=66178&stc=1
https://www.clublexus.com/forums/att...id=66177&stc=1
https://www.clublexus.com/forums/att...id=66176&stc=1
Old Apr 13, 2006 | 09:44 AM
Xeeeeeem's Avatar
Xeeeeeem
Default Dumb question
I have regular oem lights i believe, is there any way for this feature to happen in my car??
Old Apr 13, 2006 | 02:45 PM
A/X's Avatar
A/X
^^^ yes you would have to drill a hole and wire it in
Old Apr 13, 2006 | 05:46 PM
Lexus Dawg's Avatar
Lexus Dawg
I plan to do the same to my car as well when I get the time, I've been doing makeovers to my motorcycles. I already have the 194 sockets. It seems all that has to be done is to drill the hole in the back of the headlight housing to install the sockets and runt he wire. I've decided to use a simple relay and fuse (can never be too safe, right?) and wire it via the relay to a dash mounted switch, then I can turn it off/on whenever I like. In the rare instance that the fuse should blow, it doesn't affect any other lighting. I think it's best to put it on its own circuit and don't tap into anything else, I think it should work just fine!
TeaAholic1
NX - 1st Gen (2015-2021)
19
Mar 28, 2016 05:00 AM
RDWarrior
Jan 15, 2016 02:33 PM
Stoodo
HS 250h Model (2010-2012)
Mar 13, 2013 04:06 PM
eclipse641
Sep 30, 2009 04:39 PM
big basset
Jul 28, 2008 08:04 PM
