Code 71 fix*how to*?/?
Old Jan 2, 2006 | 05:52 PM
Jmai22's Avatar
Jmai22
ok, so i just remove this pipe and spray it down with carb cleaner?
Old Jan 2, 2006 | 05:56 PM
turbogs300's Avatar
turbogs300
Cool
You remove the pipe, unplug the sensor(with the car off). Unscrew the sensor, clean with wire brusk and carb cleaner. Then clean the pipe of any and all blockage or carbon with carb cleaner and gun cleaning brushes or paint gun clraning brushes.
Old Jan 2, 2006 | 06:06 PM
Jmai22's Avatar
Jmai22
ok, will do this this weekend. Thanks so much guys. anyone have any pictures from the manual that explains how to take it apart?
Old Jan 2, 2006 | 08:10 PM
link13's Avatar
link13
Hi Jmai,
I originally had the CEL and my brother cleaned the EGR value and cleared the light. It was good like that for a few months, but then the light came back one w/ code 71. I took the car for 120K service and the tech said the only way to fix the vacuum modulator was to replace it. You may be ok with cleaning the EGR for a while, but my mechanic said the vacuum modulators tend to become faulty. I don't know where it is exactly, sorry. The part was about $60.
Old Jan 2, 2006 | 08:22 PM
Jmai22's Avatar
Jmai22
Vacuum modulator
EGR Valve
EGR Sensor
Ok, so there's a few names floating around. pictures would be great at this point. so far it seems like i should just replace the Vacuum modulator since it is only 60 bucks. even though i have no idea which one is the vacuum modulator. anyone have pictures it would be GREATLY appreciated. Thanks so much
Old Jan 2, 2006 | 08:38 PM
Jmai22's Avatar
Jmai22
Hey guys, I found a picture(not of our car but similar setup/parts). Ok so basically i need to clean both of these units??? Is there a way to open them up? or do i just spray carb cleaner in them?? Also do i need to take apart the pipe right below these 2 units with all the hoses running into it and clean that out as well?
Attached Thumbnails Code 71 fix*how to*?/?-ls400engine2.jpg
Old Jan 2, 2006 | 08:52 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Originally Posted by Jmai22
Vacuum modulator
EGR Valve
EGR Sensor
I replaced my vacuum modulator and got rid of the CEL forever. Its the thing u circled in the pic.
Old Jan 6, 2006 | 12:53 AM
brianfung's Avatar
brianfung
Jmai22,
Just wondering how you have the suspension bar (The metal bar across to two front supension tower) on your NA GS300? Does it come with default option of you installed it separately.?
I want to install one to my GS300 as well.
Brian
Old Jan 6, 2006 | 12:58 AM
turbogs300's Avatar
turbogs300
Cool
Originally Posted by brianfung
Jmai22,
Brian
It's an Aristo strut bar, alot of us have them
airtraffic
Jun 5, 2011 09:36 PM
johnnyg66
May 1, 2011 05:56 AM
fooldall
Jul 24, 2007 01:23 PM
