Suspension clunking
Old Jun 24, 2023 | 01:08 PM
treehunnid's Avatar
treehunnid
2nd gear
Default Suspension clunking
Hi!
so I bought a gs300 about 2 months ago. Noticed front upper arms were abit dead. One day I hit a deep pot hole going about 30-40. Ever since had a clunking problem on the passenger side. I changed both upper arms n/s/f Lower ball joint and track rod as they both had play. Noise still hasn’t gone. Took it to one place to look and they said inner tie rods and another said possibly shock or topmount. (Also need to do driver side lower ball joint) the clunking is only over bumps not when turning? The top mounts don’t squeak. The shock isn’t showing the usual signs (continuously bouncing when hard braking and the static bounce test seems ok) I have a feeling it’s the drop link? So I guess I’m asking what would cause this? Is there a common issue on these? And if it is a shock does anyone have a set of coil overs for sale? Based uk and any help appreciated
