CA EK Waterblocks custom water cooling loop *BNIB*
$300 OBO
$390 if you were to buy these separately, my loss is your gain.
-Two 240mm magicool rads with gaskets and mounting hardware
-EK ddc 3.2 plexi xtop elite pump
-EK xres 150
-Eight or more nickel finished 3/8 EKWB fittings
-EK 3 foot 3/8 tubing
-EK Supremacy EVO plexi top (the best CPU water block they offer minus a custom ek monoblock for your specific mobo)
-EK ddc 140mm fan spider bracket
-I can throw in a 3 way 4pin pwm fan splitter if desired
Notes:
-Everything listed is brand new never used.
-One 240mm rad was rinsed by sink water but never mounted or used.
-The EK XRES150 reservoir box was opened by me and then put back inside, again never used.
-The EK Supremacy EVO has been mounted once on a ASUS motherboard using the Intel bracket but has been taken off and thermal paste has been wiped clean using arctic silvers thermal compound removing kit.
-You will need to provide your own thermal CPU compound
-You will need to provide your own 120mm radiator fans (I have EK vardar F3 and corsair ML120 white led BNIB fans but will cost extra and would need to be discussed if interested).
Located in downtown Los Angeles, cheers.
Text me at626-650-392one thanks!
-EK xres 150
Notes:
Sold locally via OfferUp app. Mods please close, thank you.
Luxor
GS - 1st Gen (1993-1997)
04-01-14 07:26 AM
