home charger
Old Oct 14, 2023 | 06:06 PM
  #136
so i used the 25A charger today to go from about 50% to 90% (mfr says car good with regular 90% level 2 charging).
after was the first time i'd actually looked at the small display on the charger 'box'. thought i'd share the pic.
33kwh stuff into the car in just over 6 hours. yes i know, this is only half the speed a 48A charger will do, but it sure beats the level 1!
Old Oct 15, 2023 | 07:17 AM
  #137
1111GS's Avatar
1111GS
There’s no cable strain, it’s plenty long enough. But that gorilla tape is no joke! I tried to pull it off of there and it would not come off. And that’s on painted concrete too…
Gorilla is no joke when the surfaces are right. I would expect if painted, it'd pull the paint off.
Old Oct 15, 2023 | 07:21 AM
  #138
1111GS's Avatar
1111GS
If I were to get a Level 2 charger installed I would get one where the plug clicks into a receptacle when its not in use like this one. I like tidy stuff:
Yeah for sure looks better than wrapping the cable around but you do lose some space if you walk around that area. I know you will most likely say, but I don't.
Old Oct 15, 2023 | 07:26 AM
  #139
I'm really surprised that it holds like that. Its painted concrete...we'll see if it holds up over time. Its a short term solution anyways.
My neighbor has that charger, you can't tell from the picture but where the plug clips into, thats like a ball joint and the handle of the plug falls down and lays flat against the charger, so the whole thing sits like maybr 9-10 inches off the wall. Its the slimmest setup I have seen. My garage is tight, so I don't want anything that takes up a lot of space. We do walk right past that all the time.
Old Oct 15, 2023 | 04:29 PM
  #140
Perfectly fine.
Old Oct 15, 2023 | 04:57 PM
  #141
Margate330's Avatar
Margate330
Originally Posted by LeX2K
Looks good to me.
Spoiler
Old Oct 15, 2023 | 05:32 PM
  #142
AMIRZA786's Avatar
AMIRZA786
With all this talk of using the dryer socket, NEMA 10-30 etc I just noticed that our washer/dryer just use standard Type B plugs:
Maybe because it's a gas dryer it just uses 120v?
Old Oct 15, 2023 | 05:33 PM
  #143
Yeah its a gas dryer lol, the outlet power is just running the electronics.
Never run an appliance through a outlet extender like that BTW...
Old Oct 15, 2023 | 05:35 PM
  #144
AMIRZA786's Avatar
AMIRZA786
Thanks, that's what I thought. This was setup by our Handyman back in 2016 when we bought the house and the new appliances. He did that because getting to the plugs in the back is lets say, a lot of work. I'll change that as soon as possible
Old Oct 15, 2023 | 05:45 PM
  #145
This is why you don’t let a handyman screw with outlets like I was saying before. Not a good idea and can easily overheat.
Old Oct 15, 2023 | 05:52 PM
  #146
AMIRZA786's Avatar
AMIRZA786
He didn't touch any outlets, he just brought the Washer and Dryer in, hooked up the gas and plugged in the Surge protector. It has a fuse that will pop if it ever gets overloaded. I would have done the exact same thing if I had done it myself.
Now that I know, I'll plug them directly in the sockets
Old Oct 15, 2023 | 06:03 PM
  #147
He should never have plugged in the surge protector. Surge protectors and circuit breakers protect against overloads, not overheating which can cause a fire.
This is an example of why I would not let a handyman wire outlets or an EV charger, they do dumb stuff like this. For instance they may back wire outlets and switches out of laziness, etc.
Old Oct 15, 2023 | 06:14 PM
  #148
AMIRZA786's Avatar
AMIRZA786
I agree with you. When it came to EV charging, I hired a licensed electrician. The washer and dryer combined don't draw anything near what the charger does.
This has been the way for the last 7 years with no issues, but I'm glad I posted this, as this is an easy fix
Old Oct 15, 2023 | 06:32 PM
  #149
Mike728's Avatar
Mike728
Says the guy who's "electrician" neighbor runs a constant 48A through her 14-50 outlet.
It just proves you can get hacks in any line of work.
Old Oct 15, 2023 | 06:46 PM
  #150
Im not my neighbor lol
