Level 2 Charging at a house as a guest
#61
...I couldn't find Tesla schematics either. Best illustration I found was this teardown video of a different charger...
The onboard STM32 microcontroller chip is one of my favorites to code in "bare metal" style programming and those chips also come with many communication peripherals already built in.
What this means is this device is already onboard equipped to communicate as a master or a slave on a network or direct connection to a host and transfer data in real time in a choice of many onboard communication protocols.
#62
i take it the plug outlet would reach via cable to any ev you have? is his dryer in the garage?
good plan
the issue typically is less about connectors than it is about wiring. for higher current/watts you need thicker copper/aluminum wires. if you tried to run 40 amps through that 30A circuit you definitely run the risk of burning down the house unless there's a breaker to stop you doing that.
i would say whatever you plan on doing, still have a decent electrician look it over or do it.
Based on my research when you are plugging in EV into a 10-30 outlet the amperage is limited because that outlet does not have a dedicated ground like a more modern 15-40 outlet which can of course operate at up to 50amps on a 60 amp breaker. Its not safe to operate a Level 2 charger on a 10-30 outlet at more than 24 amps.
I want it to charge quickly but I also don't want to electrocute anybody or burn down his house...
#63
Simple solution ⛽️🚗
#64
So some background, our grandfather built this house and our dads grew up in it. It was in the family until 7 or 8 years ago when my uncle (his dad) died and my aunt (his mom) decided she didn't want to live down there anymore, so we sold the house, it needed TONS of work. A guy bought it, and renovated it and we bought it back from him and my cousin and his wife moved down there. Issue is, the panel is an old panel that is outside on the porch and that leads me to believe a lot of the wiring in the house was not replaced or improved. All the outlets are now grounded, the house has AC now where it didn't before so I may be wrong, but the panel and the service entry were not replaced nor was the service entry brought up to the lates WV code, so I have my doubts.
Thats where my concerns come from. So its entirely possible that dryer plug may be a 14-50 plug, and if there is one in the building it may be too. I will know when I am there in two weeks.
I would say whatever you plan on doing, still have a decent electrician look it over or do it.
But thats not what I want. Thats the decision I'm dealing with, an EV would be an improvement for me 99% of the time, its how to handle this one trip. Doesn't make any sense to let this one trip I make 2-3 times a year in a car dictate what kind of car I buy.
I could drive the Pacifica, but I don't want to and my wife doesn't want to be without her van and the space she needs when I am gone.
AMIRZA786 (10-05-23)
#65
No need to over think this. Just buy a variable output charger and with the time you're going to be there you can comfortably charge at a relatively low rate, say 12 amp. You're really not going to put any strain on the circuit, you're not trying to pull down 30 or 40 amps. That same variable charger could have you charging at home at 30 amps, 40 amps or more and would charge a 16 kWh battery in no time. Just avoid a fixed rate mobile charger. You never know when you need to charge or what you're dealing with when you're traveling and the ability to adjust the rate is super helpful.
Good to have all the bases covered. I actually have three chargers:
80 amp Ford charge station pro
6/8/12/16/20/24/32/40 variable rate moile charger
10/16/20/24/32 mobile charger
bowser (10-05-23)
#66
That was exactly my thought…
#67
#68
Thats the decision I'm dealing with, an EV would be an improvement for me 99% of the time, it’s how to handle this one trip. Doesn't make any sense to let this one trip I make 2-3 times a year in a car dictate what kind of car I buy.
BayeauxLex (10-06-23)
#69
Dont want to rent a car for those trips, want to drive my awesome car. I really enjoy taking my car on that trip. We’re not just talking about a daily here, we’re talking about spending $2,000 a month on a car…I want to be able to use it when I want to use it
#70
What car are you talking about? Have you replaced your S Class or is this in the works?
#72
signdetres (10-05-23)
#73
#74
So I got back from WV, this is his dryer plug, it is a 10-30...but as I feared its very old. Not sure I would want to charge an EV through that
There is a 220v outlet in the building like I thought, but its this, what is this?!
