Problem with Contacts/Phonebook
Old Jun 19, 2020 | 02:12 PM
Ltvscout's Avatar
Ltvscout
Default Problem with Contacts/Phonebook
I had an issue where my messages and emails were no longer being registered on the screen with my Mark Levinson system. I unregistered the phone in the setup, deleted the Bluetooth connection in my phone for the car and started from scratch re-registering my phone, a Samsung Galaxy Note 9. Everything seems to have worked except now when I push the Talk button to place a call it can't find any of my contacts. When I go to Contacts in the setup in the car I see them all there. I can manually make a call from the Contacts lists but using the voice activated system it doesn't work. It says the phonebook is empty. Anyone know what step I missed or how I can correct this?
Old Jun 19, 2020 | 04:36 PM
mikemu30's Avatar
mikemu30
Do you mean FAVORITES which have to be tagged as such? By the way, that is a known issue with the messaging capability disappearing. Happened to me several times.
Old Jun 19, 2020 | 04:50 PM
Ltvscout's Avatar
Ltvscout
No, not favorites. Press talk button, say Call Joe Blow. It says can't find Joe Blow in your phonebook (or something close to that). I can no longer use the talk button to call any contacts because it says it can't find them even though they are loaded and I can manually go into contacts, choose one and make the call that way. The phonebook didn't get imported into the voice system after I reconnected things. I blew away the setup and started from scratch a number of times trying to get the calling from the voice system to work to no avail.
Old Jun 19, 2020 | 05:50 PM
mikemu30's Avatar
mikemu30
You can try your dealer tech group I guess. That's what I did when it first happened to me. No appt necessary - just drove in. But my contacts imported when the phone was unpaired and then repaired. Good luck.
Old Jun 20, 2020 | 08:46 AM
TechNut's Avatar
TechNut
Veteran: Navy
I'm afraid this happens more often than I would like to admit. It happens with my 2016 NX as well. I have better luck using the Siri Eyes Free option (press and hold the phone button on the steering wheel until I get the Siri prompt) which is then selecting the contact directly from the phone. Unfortunately, this is an Apple iPhone option and I'm not aware of an equivalent in the Android world. Perhaps some of our Android folks can offer a similar workaround. I do feel your pain though and sadly, it isn't new to this generation of ES.
Old Jun 20, 2020 | 11:02 AM
JNI's Avatar
JNI
On a 2019 ES, you activate the phones Voice Assistant by holding the voice command key. Siri or Google assistant will work.
Old Jun 22, 2020 | 11:24 AM
Ltvscout's Avatar
Ltvscout
The issue fixed itself. I tried it today and all is well again. Making a call using the voice command to call someone in my phonebook now works instead of saying the name is not found. No clue what changed between the other day and now but I'm not complaining. ;-)
Old Jun 22, 2020 | 11:46 AM
mikemu30's Avatar
mikemu30
You will be when it crashes again Just joking - glad it's resolved.
Old Jun 22, 2020 | 04:34 PM
TechNut's Avatar
TechNut
Veteran: Navy
Great news! Let’s hope it stays fixed. My 2016 is hit or miss, but I don’t have enough experience with our 2019 to confirm its behavior.
tiddleM
RX - 4th Gen (2016-2022)
Mar 5, 2020 01:41 PM
Vlad2000
Jan 29, 2020 12:19 PM
sascher18
Mar 5, 2014 12:41 PM
lalin
RX - 3rd Gen (2010-2015)
Apr 1, 2010 11:58 AM
clhug
Hybrid Technology
Jul 30, 2007 06:18 AM
