Rear bumper appliqué
Old Aug 16, 2025 | 02:40 PM
RocketMan295's Avatar
RocketMan295
Default Rear bumper appliqué
I bought an OEM rear bumper appliqué for my 2024 ES300h, and obtained the OEM mounting instructions. Since I messed up my first attempt at DIY installation, I’m hoping that some more talented members might kindly offer advice. Thanks very much!
Old Aug 17, 2025 | 09:58 AM
LexFinally's Avatar
LexFinally
I get it. I did it, and it's surprisingly challenging -- the air bubbles will drive you nuts. Slow and patient are the watchwords, and start from the middle, not from one side. Best of luck!
Old Aug 17, 2025 | 02:52 PM
Denzlex's Avatar
Denzlex
Might be worth it to a have a local auto body shop do it. Shouldn’t cost much.
Old Aug 21, 2025 | 12:03 AM
sc430sc's Avatar
sc430sc
It’s applied similar to PPF and window film.
1) Clean the bumper free of lint dust etc. Don’t use wax.
2) Use a spray bottle with water and add several drops of liquid soap. Take the protective backing off. Try not to touch the adhesive, you can use tape to hold the film vertical (so no dust lands on the film) when your spraying the back of the film.
3) Position the film on the bumper (it should slide around fairly easy with the water/soap solution while positioning it).
4) Once positioned, spray the top of the film (squeegee slides easier and won’t scratch it) and use a small rubber squeegee starting from the center working towards the edges to get the water bubbles out.
5) once all out your done! Let it cure overnight (the water should evaporate out).
Old Aug 22, 2025 | 11:32 AM
zul8tr's Avatar
zul8tr
Is the applique still useable from your 1st try?
sc430sc has the right solution if film still useable.
Freds430
Aug 15, 2017 05:11 AM
dwilly58
Nov 6, 2011 11:28 AM
mpcguru
May 26, 2004 09:39 PM
