Transmission Cooler Bypass Location
Old Aug 13, 2025 | 03:50 PM
artbuc's Avatar
artbuc
Default Transmission Cooler Bypass Location
CCN says to pin cooler bypass open to ensure correct fill on the 8 speed UA80E trans. I have this on my 2020 ES. Does anyone know where the bypass is? Can you see/access it when you remove bottom cover panels? Thanks.
Old Aug 14, 2025 | 06:30 AM
artbuc's Avatar
artbuc
I got a 2 day subscription to TIS and looked at the Repair Manual. The ATF cooler is located under the battery. But, I see no reference to the thermostatically controlled bypass the Car Care Nut mentions in his video. ATF inlet and outlet hoses run directly between transmission body and cooler. So, it the thermo bypass exists, it is internal. I also looked at the transmission system itself and found no reference to the bypass.
So, maybe some UA80E tranny’s have it and some don’t.
Old Aug 14, 2025 | 07:01 AM
hotwings's Avatar
hotwings
I found this UA80F which might help. Slightly different transmission.
Post #11 has a video.
Old Aug 14, 2025 | 07:33 AM
artbuc's Avatar
artbuc
Thanks, I watched that too before I bought my subscription. RM shows a different style cooler for my car.
In order to access RM, I have to enter production date. They only give two options in the drop down menu. Neither applies to my car which was made 8/2020. Option closest to mine ends with 1/2020. So, maybe only way to tell for sure is to remove battery.
Old Aug 14, 2025 | 09:53 AM
artbuc's Avatar
artbuc
The depicted part 32970-34030 does not fit any vehicle with a UA80E/F transmission. But, the later model UA80E/F has what the RM calls a water bypass hose assembly. It looks like it is electrically controlled. Looks like only UB80E/F trans (low torque) have the thermostatic bypass 32970-34030.
The 8 speed appears to have many permutations. The RM does not say anything about the thermostatic bypass as it relates to setting ATF level.
Old Aug 14, 2025 | 10:33 AM
grp52's Avatar
grp52
In The Car Care Nut's "How to change your Toyota Sealed Transmission Fluid" video's description, he states:
Notes on 8 speed transmission:
-The cooler bypass will be located between the transmission and the radiator, you have to remove the front driver's side splash sheild to access it (10mm screws and clips) Also this only applies to some 2017-2020 highlander and 2017-2020 sienna models. If your highlander or sienna doesn't have it then skip the cooler bypass part.
The part I've bolded, I think, makes clear only some of the "new" 8 speed transmissions (e.g., UA80E) have an oil cooler bypass.
Old Aug 14, 2025 | 10:37 AM
Could be wrong but I think 32970-34030 is only for trucks or the LX aka Land Cruiser.
Old Aug 14, 2025 | 11:35 AM
artbuc's Avatar
artbuc
Thanks, I never thought to read the description, crap! That clears up my confusion.
Old Aug 14, 2025 | 03:50 PM
artbuc's Avatar
artbuc
Ok, I looked at the RM for 2017-2020 Sienna. It shows the ATF (transmission oil) cooler thermostat. But, the ATF replacement procedure does not mention it. So, it looks like CCN’s video is asking for a refinement not called for by Toyota. Not unusual since he often calls for more stringent service than Toyota, eg calling for ATF replacement at 6 years regardless of mileage.
artbuc
ES - 7th Gen (2019-2025)
12
Aug 14, 2025 11:23 AM
docbhn9
16
Nov 21, 2023 01:48 PM
Dallas250
Dec 19, 2022 05:49 AM
jamesf8
Nov 24, 2021 02:19 AM
gcrim21
Dec 17, 2004 04:56 PM
