What is this snowflake icon?
Old Jan 5, 2024 | 05:08 PM
minotaar's Avatar
minotaar
Default What is this snowflake icon?
New owner here, clueless about this icon that started appearing with cooler temps. Is it just a warning to be careful about icy roads? Or something more specific?
Old Jan 5, 2024 | 05:14 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Thats a heads up that bridges freeze when the temp hits 37 degrees.
Old Jan 5, 2024 | 05:37 PM
Denzlex's Avatar
Denzlex
The flashing icon helps draw your eyes to the temperature readout to warn of potential ice on the road.
Old Jan 5, 2024 | 08:30 PM
grp52's Avatar
grp52
To add to other posts, see page 75 (hybrid model) or page 67 (non-hybrid models) of the 2024 Owner's Manual where the icon is listed with the following label and footnotes:
Low outside temperature indicator*3, 6
*3: This light illuminates on the multi-information display.
*6: When the outside temperature is approximately 37°F (3°C) or lower, this indicator will flash for approximately 10 seconds, then stay on.
Old Jan 6, 2024 | 06:44 AM
SonOfABisc's Avatar
SonOfABisc
Are you younger than 30?
Old Jan 6, 2024 | 01:56 PM
ESh's Avatar
ESh
Do you guys read the manual at all?
Old Jan 6, 2024 | 03:23 PM
mikemu30's Avatar
mikemu30
It's so much easier to just ask here🤣
Old Jan 6, 2024 | 08:56 PM
minotaar's Avatar
minotaar
I searched. When searching for snow, snowflake, and cold, nothing related comes up.
Yes. It is easier to ask here.
Old Jan 7, 2024 | 05:45 PM
BBQapple's Avatar
BBQapple
The manual is pretty awful to be honest. It should be a third of the length which it could be if they didn’t let lawyers have their say.
Old Jan 10, 2024 | 01:46 PM
losiglow's Avatar
losiglow
That means it's cold.
Really - it's just a reminder that the roads might be slick due to low temperature. I can only assume it comes on at 37 F because the roads might be cold enough (32 F) at that point to freeze. So it's sort of a extra-safe warning even though air temps may not have reached 32 F yet.
I used to think it was silly but in practice, it does remind me to slow down on bridges or onramps because those can freeze before normal roads.
Old Jan 10, 2024 | 02:04 PM
minotaar's Avatar
minotaar
Thanks. It would be cool if the car did more in terms of performance when it detected low temperatures. Maybe a higher threshold for turning on ABS, or blasting the heat when it first turns on.
Margate330
Sep 3, 2021 10:14 PM
Ericspyder
IS F (2008-2014)
May 9, 2020 06:08 PM
airgas1998
Jan 10, 2016 07:41 PM
LexFather
Aug 5, 2005 09:07 PM
LexFather
Jun 20, 2005 04:24 PM
