Powered add-on sub with ML?
Old May 28, 2022 | 09:07 PM
LS500Fan's Avatar
LS500Fan
Default Powered add-on sub with ML?
Has anyone here added a sub to the ML system? I want deeper bass. Like 10” minimum I think. I have ‘22 ES300h.
Looking for experiences and recommendations…
What wires should I tap? The woofer on the parcel shelf?
Old Jun 3, 2022 | 10:18 AM
E46CT's Avatar
E46CT
If you read some of my early posts, you'll see I was the pioneer in this area and the first to do it. Re-read my posts but IIRC the wiring is the same for ML and non-ML in terms of what to tap. Definitely do not tap on the parcel shelf. You're going to need to access the amp directly under the seat.
Old Jun 3, 2022 | 11:26 AM
doncmleon's Avatar
doncmleon
I added the Rockford P300 10" powered sub about a month ago. I dont have the ML system. LOVE the sub! Highly recommend it, too. It's not going to get you in trouble and it's more than enough for me.
. Also be sure to disconnect the ANC system (Active noise control) TRUST ME - you'll need it.
Old Jun 3, 2022 | 11:28 AM
doncmleon's Avatar
doncmleon
This in addition to E46's thread will help A LOT
https://www.clublexus.com/forums/lex...dio-build.html
Old Jun 3, 2022 | 12:38 PM
E46CT's Avatar
E46CT
I think the P300 is what I use too. I'm debating switching to the 12" version. At least its plug and play and the hard part is done.
and yes you'll need to disable ANC. i was the first to discover you can disable it through carista. everyone (at the time) was saying you have to snip this wire or that wire or have your dealer do it etc.
Old Jun 3, 2022 | 01:23 PM
doncmleon's Avatar
doncmleon
On the ANC....I dont think the Carista app works anymore . At least it doesnt on my 2019 F Sport. I found that you dont even need to use the app. Just remove the head rest, move the seat forward as far as it will go, raise the seat, remove the amp cover and disconnect the middle section wiring harness on the amp....and you're done.
Thats what Sonnie did in the thread I pasted. Post #4 in his write up
Free and super easy to do. Took me about 10 min from start to finish.
Old Jun 3, 2022 | 01:27 PM
E46CT's Avatar
E46CT
From what I remember from purchasing the official Toyota wiring diagrams, that middle harness has other responsibilities other than ANC.
My car is a 2021 and Carista worked to disable ANC. $9.99 for a one month subscription that allows you to customize other parameters is well worth it.
Old Jun 3, 2022 | 01:51 PM
doncmleon's Avatar
doncmleon
Yeah that little Carista is cool. I ended up using for other customizable things. No regrets!
Im not sure about that middle harness part, because Sonnie and myself havent had any issues with it. Everything else is working fine.
Old Jun 3, 2022 | 03:37 PM
E46CT's Avatar
E46CT
From what it looks like from digging into the diagram, that harness you pulled does in fact include components to the ANC but also looks like a voltage signal detection wire for overheat/fuse circuit protection. Also other wires potentially relating to telematics transceiver protection and some other fuses. Though a lot of it is really technical so not sure. Personally I'd plug that back in and disable ANC the correct way through settings since it's also how the dealer does it. They would not devote an entire wiring harness to just ANC. That harness is shared and appears to integrate a lot of vehicle functions to it.
Old Jun 3, 2022 | 03:50 PM
doncmleon's Avatar
doncmleon
Yeah, im not going through all that. Im good. System sounds great and no issues since. Another option for some could be just unplugging the 3 mics. If I ever noticed something weird that's what I'd do.
Old Jun 3, 2022 | 04:13 PM
E46CT's Avatar
E46CT
Just to me, a factory allowed setting to disable is much more cleaner and elegant and sure than undoing stuff.
Old Jun 3, 2022 | 07:06 PM
doncmleon's Avatar
doncmleon
cool
Joeyblanco
Aug 12, 2021 03:00 PM
Trocks797
Apr 23, 2013 06:56 AM
muf-dvr
Feb 20, 2012 06:36 AM
lukeisf
IS F (2008-2014)
27
Aug 20, 2011 12:30 AM
OGS
Jan 1, 2006 10:52 AM
