2019 ES350 17K miles
My observation, owning a 2019 Ultra Lux ES 350, is that the optional noise reduction wheels are useless. It's difficult to compare but I can't discern any difference between my 2013 Lux ES 350 wheels and the 2019 UL with the optional NR wheels... IMO it all comes down to tires with correct pressure and maybe the premium window glass (which I also have).
As others have said the biggest difference maker with regard to a quieter cabin is likely the tires and the size of the wheels. On very smooth pavement, I didn't see much difference between the 17" wheels with Michelin tires on my 2013 ES and the 18" wheels with Michelin tires on my 2017, But, on less than smooth pavement, the bigger wheels and lower profile tires on the 2017 produced much more noise than did the smaller wheels and higher profile tires on the 2013.
While I couldn't find a specific sound dampening comparison between automotive tempered window glass and AGC automotive's normal laminated Lamisafe product, I did find a comparison graph from Saflex (a different glass company) which has similar comparison curves between normal and acoustic laminated glass that also includes a tempered glass curve along with frequency range bars with labels classifying the range associated with different types of automotive noises, e.g., road, wind, etc. The [Saflex] Sound transmission loss at 20℃ graph shows in red the tempered glass, in purple a normal PVB laminated glass, and in green and blue their offerings of acoustic interlayer laminated glasses.
While one can surmise between the two sets of comparison graphs the Laminated Glass Lamisafe product used in the UL does have better wind noise dampening properties than regular tempered glass, a specialty acoustic laminated glass will provide significantly much greater sound dampening in the wind noise frequency range.
P.S. LexWannabe, there's no particular reason I'm making this acoustic glass comment as a response to your posting. Your posting was just an innocent "drive by" that was convenient to latch onto with the additional "acoustic" glass clarifying info.
LexFinally (01-09-23)
High expectations
I suspect your expectations may be a little high. Unfortunately the car periodicals may build some brands up a bit too much. My observation has been much like yours, slightly quieter at highway speeds than other brands I have owned, but certainly not stealthy quiet. These cars have been designed to be very lightweight (for their size) and consequently they aren't like the old 1970's caddy's that were whisper quiet at about any speed and on any road surface. You certainly have the best tire/wheel combo for a smooth quiet ride so I doubt you are going to get much better. The hybrids and Ultra Luxury models supposedly had better sound deadening but I have no idea if that "claim" is accurate as I have only driven base and luxury package hybrids.
the ultra luxury version has special tires and double panel glass to improve sound deadening.
thar said, I do not have that and was also surprised that the sound was loader than I expected when I got an ES. That said, it was still much quieter than my prior cars (all Hondas and acuras). I think it would be hard to find a car that would remain quiet on bad roads or groved pavement.
Luxury and UL have the noise reduction wheels, not the tires.
The anount of sound deadening is the same, but the hybrids have more sound insulation between the engine and the compartment.
The wheels, yes. In addition, I can speak only for my '22 Ultra -- my stock Bridgestone Turanza tires are claimed by the Bridgestone web site to combine "precisely tuned and tested enhancements in the tread to help dampen road noise". Every little bit helps.
Marketing nonsense. Sort of like tartar control toothpaste.
Just FYI the OEM Bridgestones are horrible tires. Mine were done at 20k miles even with regular rotations. I also had a mind numbing booming and vibration at highway speeds that I thought was a bad wheel bearing or two. Turns out it was those POS tires. Read the reviews on Tirerack; my experience appears quite common.
I’m interested in maximizing the smooth and quiet ride on my 2021ES 350. Are the Goodyear Maxlife Assurance that much better than those that came with the car? What makes are these Maxlife tires superior? I’ll get them next time rather tha. Replacing stock with stock if they’re superior.
Dealership delivered my car at 40psi. Rides on the 18s much better at 35psi and no noticeable impact on MPG.
