Need Purchase Help - Is this the same car?
Old Dec 29, 2025 | 05:30 AM
Trvlngnrs's Avatar
Trvlngnrs
Default Need Purchase Help - Is this the same car?
Heading to a dealer about 1,000 miles away to purchase a L/Cert 2024 ES 300h. Last night, in the hotel, I started questioning their photos. Are these the same car?
Also, the Carfax says there has been 3 owners. Owner 1 sold it to owner 2, who sold it to the dealer, who is the 3rd owner. It that anything to be concerned about?
Blessings,
​​​​​​​Trvlngnrs
Old Dec 29, 2025 | 05:36 AM
cpq100's Avatar
cpq100
Maybe it is the angle of the photo, but the car in the top photo does not appear to have a rear spoiler like the one in the bottom photo.
Old Dec 29, 2025 | 06:15 AM
ATL350's Avatar
ATL350
Good catch - and the hybrids all come with the spoiler.
As to the cons=fused ownership ... I don’t know that I exactly trust the accurate of CarFax for everything. At the very least, you should ask the dealer to printout the vehicles service history. If it’s L-certified, they certainly can see any work done on it.
Old Dec 29, 2025 | 07:25 AM
E46CT's Avatar
E46CT
top one has a bald spot but looks like that could be AI trim/ai placement/AI slop and it trimmed the spoiler off.
Old Dec 29, 2025 | 09:26 AM
rVague's Avatar
rVague
Big question- why 3 owners. That’s a big red flag.
Old Dec 29, 2025 | 10:50 AM
E46CT's Avatar
E46CT
first thing i would check for is rattles. test drive it for a long time. see if they can do an overnight test drive.
Old Dec 29, 2025 | 11:24 AM
ESh's Avatar
ESh
It is not. If the dealer got the title on their name then it is the third owner
please send me the VIN number so I can check.
Old Dec 29, 2025 | 03:37 PM
Trvlngnrs's Avatar
Trvlngnrs
Thank you, here's the VIN: [size=13px]58AEA1C18RU048076
Here's the history after I entered the VIN into My Lexus: [/size]
12/1/2025 (12652 miles)REPAIR NUMBER: 0575062
REPORTED BY: Lexus of Omaha
SERVICE: 25LA06 - UPDATE PARKING ASSIST ECU SOFTWARE ON ES, NX, RX
DESCRIPTION: ~|~SAFETY RECALL 25LA06 (REMEDY NOTICE) - MULTIPLE MODELS AND MODEL YEARS - REAR VIEW CAMERA IMAGE MAY FREEZE OR NOT DISPLAY. ~|~CAMPAIGN ~|~12652 25LA06 PERFORMED 25LA06 RE CALIBRATION.
SERVICE: LEXUS CERTIFIED PRE-OWNED INSPECTION
DESCRIPTION: ~|~LEXUS CERTIFIED PRE-OWNED INSPECTION ~|~ ~|~12652 CERT UCI COMPLETE. TIRES 6/32, FBP 10MM, RBP 8MM. QUOTED ALIGNMENT, BLADES.
SERVICE: COMPLETE 4 WHEEL ALIGNMENT SERVICE STEERING WHEEL OFF CENTER REC REPLACING.
DESCRIPTION: ~|~FOUR WHEEL ALIGNMENT ~|~ ~|~12652 PERFORMED FOUR WHEEL ALIGNMENT, ADJUST CASTER, CAMBER AND TOE AS NEEDED PERFORMED FOUR WHEEL ALIGNMENT, ADJUST CASTER, CAMBER AND TOE AS NEEDED
SERVICE: DETU
DESCRIPTION: ~|~COMPLETE DETAIL FOR PRE-OWNED DEPARTMENT ~|~
SERVICE: STREAKING REC REPLACING.
DESCRIPTION: ~|~INSTALL WIPER INSERTS ~|~ ~|~12652 BLADE REPLACEMENT COMPLETE.
SERVICE: PAINTLESS DENT REPAIR
DESCRIPTION: ~|~PAINTLESS DENT REPAIR ~|~PRE-OWNED DEPT. REQUESTED ~|~12652 PDR 5 PDR COMPLETED
9/2/2025 (10689 miles)REPAIR NUMBER: 0797116
REPORTED BY: Willis Lexus
SERVICE: 10,000 MILE FULL SERVICE LEXUSCARE
DESCRIPTION: ~|~CUSTOMER REQUESTS 12-MONTH, 10,000-MILE COMPLIMENTARY MAINTENANCE SERVICE: CHECK INSTALLATION OF DRIVERS FLOOR MAT, RESET MAINTENANCE REMINDER, ROTATE TIRES, PERFORM ENGINE OIL AND FILTER CHANGE, TOP OFF ALL FLUIDS, REPLACE CABIN FILTER, AND MULTI-POINT I ~|~LEXUSCARE COMPLIMENTARY MAINTENANCE - CHECK FOR UPDATES, CHECK FLOOR MATS, RESET MAINTENANCE REMINDER, PERFORM ROAD TEST, ROTATE TIRES, REPL
SERVICE: CUSTOMER REQUESTS MULTI-POINT VEHICLE INSPECTION
DESCRIPTION: ~|~CUSTOMER REQUESTS MULTI-POINT VEHICLE INSPECTION ~|~RECOMMENDED MAINTENANCE ~|~10689 PERFORMED MULTI-POINT INSPECTION. 9494 MPI OIL 9591 ROTATION CABIN
1/29/2025 (4959 miles)REPAIR NUMBER: 0770718
SERVICE: EXTERIOR WASH, DRY, APPLY TIRE DRESSING, REMOVE STICKERS FOR DELIVERY
DESCRIPTION: ~|~EXTERIOR WASH, DRY, APPLY TIRE DRESSING, REMOVE STICKERS FOR DELIVERY ~|~
1/9/2025 (4959 miles)REPAIR NUMBER: 0767970
SERVICE: PAINTLESS DENT REMOVAL
DESCRIPTION: ~|~PAINTLESS DENT REMOVAL ~|~
1/9/2025 (4958 miles)REPAIR NUMBER: 0767618
SERVICE: LEXUS CERTIFIED PRE-OWNED INSPECTION 001014
DESCRIPTION: ~|~LEXUS CERTIFIED PRE-OWNED INSPECTION 001014 ~|~ ~|~4958 CERTIFIED PRE OWNED INSPECTION COMPLETED.
SERVICE:
DESCRIPTION: CUSTOMERREQUESTS LUBE, OIL AND FILTER CHANGE, PERFORM MULTI-POINT VEHICLE INSPECTION - LEOIL ~|~CUSTOMER REQUESTS LUBE, OIL AND FILTER CHANGE, PERFORM MULTI-POINT VEHICLE INSPECTION - LEOIL ~|~ ~|~4958 REPLACED MANUFACTURER RECOMMENDED ENGINE OIL AND FILTER. RESET SERVICE INDICATOR WHEN REQUIRED.
SERVICE:
1/9/2025 (4958 miles)REPAIR NUMBER: 0767885
SERVICE:
DESCRIPTION: RECONDETAIL - STEAM CLEAN TOP AND BOTTOM OF ENGINE COMPARTMENT, REMOVE TAR, SHAMPOO INTERIOR, CLE ~|~RECON DETAIL - STEAM CLEAN TOP AND BOTTOM OF ENGINE COMPARTMENT, REMOVE TAR, SHAMPOO INTERIOR, CLEAN TRUNK, BUFF AND WAX VEHICLE. ~|~
SERVICE:
SERVICE: CUSTOMER REQUESTS INTERIOR REPAIR AND DOOR EDGE GUARD INSTALLATION
DESCRIPTION: ~|~CUSTOMER REQUESTS INTERIOR REPAIR AND DOOR EDGE GUARD INSTALLATION ~|~
4/24/2024 (27 miles)REPAIR NUMBER: 0736185
Old Dec 30, 2025 | 07:46 AM
E46CT's Avatar
E46CT
Seems alright? This prior owner had good motives changing oil at 5k.
but not motives like me. i changed my ES oil at 600 miles (if an ES didn't do this around 600-1k miles like car care nut instructs us to, then i feel sorry for that engine later in life) whoever got my ES out there doesn't know that it was maintained by a super-enthusiast. cleanest ESH engine around.
always change oil on a new car at 600-1000 miles. it's safest for the cylinder walls due to the debris that CCN says circulates -- you won't notice the effects til way later in the cars life and the downhill trajectory will begin slowly and creep up.
or... don't. your call
Old Dec 31, 2025 | 09:09 AM
Trvlngnrs's Avatar
Trvlngnrs
Thanks for your thoughts guys. The salesman was shocked when I showed him the photos. He says they use photoshop and wasn’t sure if they use AI on the photos. The car does have the rear spoiler
Old Dec 31, 2025 | 09:39 AM
tfischer's Avatar
tfischer
25 Year Member
That dealer needs to talk to his IT team. They should only use Photoshop to crop the photos (which is using a chain saw to cut butter) and not much more. It looks like they used the "remove background" or "select Image" function to allow Photoshop to "select" what it thinks is the subject of the photo. I have used this a lot, but it often makes mistakes around the edges, which need to be inspected before saving. I think that the function, in selecting the car, cut off the small profile of the spoiler, which is not at all surprising to me, but in a sales tool, that can be misleading, lead to a misunderstanding with the customer, and result in a lost sale or at least a feeling on the customer's part that the dealer is not fully informed of his products, runs a sloppy operating, and does not review his representations.
In some circumstances, the use of Photoshop's automated AI functions ("generative fill," the "remove tool," "generative expand," etc., which are amazing tools) without human supervision, can easily lead to ugly litigation.
Old Dec 31, 2025 | 11:49 AM
scubapr's Avatar
scubapr
Originally Posted by tfischer
That dealer needs to talk to his IT team. They should only use Photoshop to crop the photos (which is using a chain saw to cut butter) and not much more....
Agree, or perhaps the salesperson used some AI photo tools on the phone to achieve the same effect. The second photo appears to have clouds reflected on the front door glass in what it looks indoors background.
Honestly, I’d be pretty upset if I traveled 1k miles only to find the car looks nothing like the pictures. Aside from that, the key thing is making sure the maintenance records are solid and that the warranty isn’t restricted to just that dealer 1k miles away. Just make sure to test drive thoroughly.
Best of luck to the OP, and Happy New Year to everyone!
Old Dec 31, 2025 | 05:39 PM
Trvlngnrs's Avatar
Trvlngnrs
He admitted the photos are taken outside, despite the photos on the website looking like they are inside.
Other than that, it's L/Certified. They contacted the nearest Lexus dealer to me and confirmed they have loaner vehicles, as it's 100 miles from home.
Overall a good experience, despite the photo blunder. 2024 ES 300h Luxury w many UL upgrades: ML, Pano camera, Auto trunk, HUD, NR wheels, Window tint, Door sills, floor & trunk mats, etc. No triple beam lights though. Paid $42,900 OTD with $31,000 trade in for a 2021 Chevy Colorado ZR2. I'll pay 6.75% sales tax when I get home on the $11,900.
Drove over 500 miles today... it's the best driving car I've ever owned. I was worried about the hybrid... but it had plenty of power. A group of cars and trucks stayed together cruising 85 - 90 over 120 miles on an empty freeway and I still averaged 38mpg.
Old Dec 31, 2025 | 06:06 PM
tfischer's Avatar
tfischer
25 Year Member
Clearly, that's not the photo they started with to get the one in your original post. They really need to brush up on their Photoshop skills.
I put your new photo into Photoshop and did two automatic tasks. (I am not skilled in graphics; I'm a retired attorney.) First I clicked on "remove background," and in 3 seconds I had just the car and everything else was transparent. Then I clicked on "Generate background" and typed "on the beach" - in 5 seconds I got the photo you see here (including the sat antenna and the spoiler).
What I think they should do is get a nice photo of the front of their dealership. Photoshop can put any car photo with the background removed (which takes one click) onto their photo of the dealership driveway. Then, instead of "on the beach" you just paste the background photo you want to add and the result will look real and not be misleading, and that process will take less time than they probably took screwing up that first photo.
So glad you like the ES350. I've had mine for two years now, and it's a joy to drive.
Happy motoring and Happy New Year.
Old Dec 31, 2025 | 10:28 PM
scubapr's Avatar
scubapr
Originally Posted by Trvlngnrs
...Overall a good experience, despite the photo blunder. 2024 ES 300h Luxury w many UL upgrades: ML, Pano camera, Auto trunk, HUD, NR wheels, Window tint, Door sills, floor & trunk mats, etc. No triple beam lights though...
At first, I wasn’t interested in the 360 camera or hands-free trunk, but now I can’t imagine living without them. With the 360 view, you can press the "view" button while front parking to get a clearer view of what’s ahead; great for avoiding parking bumpers. I also find myself with both hands full often, so being able to open the trunk with a foot swipe has been incredibly useful.
As for the triple-beam headlights, you’re not missing much. They look great, and I enjoy the startup “dance”, but performance-wise, they’re almost identical to the non-triple beams according to multiple sources, including IIHS.
https://www.iihs.org/ratings/vehicle...024#headlights
Drove over 500 miles today... it's the best driving car I've ever owned. I was worried about the hybrid... but it had plenty of power. A group of cars and trucks stayed together cruising 85 - 90 over 120 miles on an empty freeway and I still averaged 38mpg...
After nearly 30 months of ownership, and 11k miles, I’m still very happy with my 300h purchase. What continues to impress me is the smooth, almost unnoticeable transition between EV mode and the gas engine; and the silent startup. On the highway, if you drive in ECO mode and keep your speed between 60–75 mph (especially in warmer weather), you can easily achieve over 48 mpg. It also has plenty of power, particularly in Normal or Sport mode. I typically use Normal or Sport for city driving and ECO for highway trips, and I average between 40-46 mpg per tank. I also have the same iridium color.
Only dislike is the constant hissing sound from the brake booster, which is quite noticeable in the otherwise very quiet cabin.
Congrats on the new ride!
