Auto-fold Mirrors
I have a UK premium spec ES300h. It has power folding mirrors but not auto-fold to enable auto folding on locking. The mirror switch doesn’t have the ‘auto’ option (middle position) on it unlike the F-Sport or Premium Plus models. If I buy a window/mirror control panel with the ‘auto’ option on it, will it work on my car?
That's interesting, and I of course don't know, but it may be because some local regulation. If that is the case, replacing the switch might work. Folding mirrors without auto-fold really limits their usefulness.
Dave Mac
Dave Mac
No it doesn’t. The UK Premium spec model doesn’t have auto-fold mirrors or the memory position option. But it does have power folding. So I’m trying to find out if replacing the window switch panel for one with the ‘auto’ position on it will work.
Thanks, that would be great. It’s
JTHB21B1X02204919
JTHB21B1X02204919
Nothing is the same, but still I cannot rule out that option.
The cheapest would be to buy a used switch. This is the part number: 84872-78030
I wonder where the switch or sensor is that triggers the mirrors to auto-fold. If it is in the switch itself, perhaps it would work, but if there is wiring that leads to one of the many onboard computers you may be out of luck.
I’ll know soon. I bought one of switches with the ‘auto’ option.
I got curious about this...locked and unlocked the doors using the proximity sensor....mirrors folded/unfolded. Tried with the remote push button...mirrors folded/unfolded. Tried using the manual "key"...mirrors did NOT fold nor unfold. Used the inside door lock switch, mirrors did not move. Also, when putting the car into or out of gear the doors lock/unlock as programmed but the mirrors do not move. There must be some logic that controls whether or not the mirrors fold/unfold. It'll be interesting to see what happens with the switch change (provided that the connectors are compatible).
When the front doors are closed, each power window regulator motor assembly can be operated for approximately 45 seconds after the engine switch is turned from on (IG) to off by receiving operation permission signals from the main body ECU (multiplex network body ECU). However, when approximately 45 seconds have elapsed, or the driver door or front passenger door is opened within approximately 45 seconds of the engine switch being turned off, the power window regulator motor assemblies stop operating.
During auto operation, when 45 seconds have elapsed and key-off operation is prohibited, the power window stops immediately.
Also, there's a (US) "Programmable by Dealer" "Automatic Mirror Fold and Extend" setting that will change the behavior of the various operational states. I assume you tested with the default "Fold linked with door lock (Default)" setting, so the behavior you witnessed with that setting won't necessarily be the same as the behavior for the two other possible settings for that programmable option.
As to whether or not a simple switch swap will enable auto folding for chuckyarla's UK sold ES, I think that's going to depend upon the firmware loaded into the controlling ECU his ES is equipped with.
