Flickering headlights
Old Feb 4, 2025 | 03:12 AM
highllundd's Avatar
highllundd
BANNED SCAMMER
It could be the led driver module is going bad
Old Feb 4, 2025 | 03:28 AM
es250fsport's Avatar
es250fsport
Doesn't look like it. It is the reflector motor.
Do they need to replace the whole headlight or the reflector motor itself?
Can these be opened safely and glued back together?
Old Feb 4, 2025 | 05:26 AM
ESh's Avatar
ESh
No, they don’t fix them. They replace them.
ESh's Avatar
ESh
Why you think the driver module is bad?
Old Feb 4, 2025 | 05:29 AM
ESh's Avatar
ESh
Originally Posted by es250fsport
What the hell is reflector motor?
https://pressroom.lexus.com.au/Press...b-213eac243a21
Does that mean they will replace the whole headlight assembly or just the part inside ?
Does that mean they will crack open this headlight and manually put it/glue it together?
On bi-led/tripple beam, you have the same LED-s for low and high beams but there’s a reflector door which covers the upper half of the reflector for the low beam and fully opens for the high beams.
As I explained to you before they will replace the whole assembly.
Old Feb 4, 2025 | 05:49 AM
es250fsport
Thanks for clarifying that.
Not sure why they don't just say "we will replace your headlights with a new one". Instead they are talking about reflector motors.
I assume cars in the USA is also affected right ?
Old Feb 4, 2025 | 02:05 PM
ESh's Avatar
ESh
That’s not a common problem.
Old Mar 8, 2025 | 07:11 AM
es250fsport
Christmas lights are on early this year.
dbsoccer
RX - 4th Gen (2016-2022)
Dec 14, 2023 03:12 AM
docbhn9
ES - 7th Gen (2019-2025)
Dec 12, 2023 12:35 PM
quicksig
Mar 13, 2008 07:41 PM
Jubane
RX - 1st Gen (1999-2003)
Nov 5, 2005 02:45 PM
