Is it worth replacing front door speakers on non-ML?
Old Sep 15, 2024 | 07:57 AM
F3Woody's Avatar
F3Woody
Default Is it worth replacing front door speakers on non-ML?
I thought I remembered someone saying it isn’t because only low end signal goes there but has anyone done this?
Old Sep 16, 2024 | 12:04 PM
losiglow's Avatar
losiglow
They're correct about low-frequency, at least in the ML system.
But even in the ML, replacement of the front lower speakers was worth it in my opinion. Much better base response than stock. I went with Rockford Fosgate R169x2 in that spot but I'm sure the Kickers would also do a fine job. I used the Kicker KS series 3.5" for the other speaker hard points.
Old Sep 18, 2024 | 11:29 AM
DocEnuf's Avatar
DocEnuf
I have a 2020 ES non-ML and the speakers I ordered from Crutchfield was suppose to fit. They were not even close. They were WAY different than any aftermarket speakers so I just sent them back and left what I had here.
Old Sep 18, 2024 | 12:44 PM
losiglow's Avatar
losiglow
They weren't the same in the ML equipped vehicles either. The bottom front speakers are more of a 6x8 rather than a 6x9. Crutchfield provided an adapter mount that worked fairly well to mount them correctly though I still have to make a few holes in the mount to fit the ones in the door.
Old Sep 19, 2024 | 06:11 AM
F3Woody's Avatar
F3Woody
I went ahead and did it. Definitely worth. As others have said, the difference in weight & mass from the stock is almost laughable.
Crutchfield said they fit but in hindsight I should have gone with a round option rather than 6x9, for a potentially more seamless install. I had to trim two tabs at the bottom for the door panel to fit back on, and currently only have 3 screws in. I shimmed the one corner without a screw with adhesive felt pads and it was pretty snug. I don't notice any vibration or rattling so I'm okay with it.
Also, the Toyota Metra wiring harness for $10 is 100% worth it. Snaps right on, no cutting or splicing needed.
schmauster
GX - 1st Gen (2003-2009)
Sep 12, 2021 06:42 PM
NXNoob
NX - 1st Gen (2015-2021)
Jul 13, 2020 08:19 AM
cjbdvm04
Feb 10, 2005 09:41 AM
