Yes, I have them. They look pretty good and fit properly. The only problem I’ve had is on one or two of them the ends are coming up a bit as the adhesive tape is not sticking as well, I think because the handles have a slight curve and that makes them pull up a bit at the end. I’m looking for a solution, but otherwise they do dress up the car which, IMO needs some chrome added.
They look good. Theres a trick to this. I had the same problem you had and just stuck them on hoping the adhesive is strong enough for it to hold. After a couple washes they bent outward, sticking sideways.
Had to get a second set and pre bent them (more so on ends, making sure their curvature is greater than the door handle, so at least they touch the handles), and never had a problem since.
Careful not to bend them to much though as there will start to craze on the chrome finishing.
It doesn't hurt to use some isopropyl rubbing alcohol on the piece that you're sticking them to first too, then fan it to make sure that it's dry. It helps to make sure that all of the dirt/dust/oils/whatever are off of it and helps with adhesion.
I bought a set for my ESh when I had it. i never installed it. I still have them in the garage. i'm thinking of taking them out back and stamping them with my feet. what else will i do with them.
which reminds me i still have a fit cam x dash cam and illuminated sills.
Would you be willing to post a picture of your car with the chrome covers on? I can't get sense of how these look on the car, and sort of curious for myself.
